-   -   Backseat Buildup Recommendations??? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/262163-backseat-buildup-recommendations.html)
fantastixvoyage 09-12-2011 12:12 PM
Need to build a backseat from scratch and looking to gather some details on other examples.
If anyone has buildup pics or pics of their seats with and without the foam/vinyl that would be great. Trying to see what the main base needs to look like.
Plan to be a semi divided seat with a step or two built in but be neat to see what others have done out there.
rchuntlsl 09-13-2011 07:34 PM
You can use 5/8 or 3/4" ply wood to build it up. I would get some economically priced epoxy and mix up a bunch and seal up the plywood on all sides before you cover it with foam or vinyl.
hadleycat 09-13-2011 09:04 PM
Hey Neil, How do you want to finish the base? If you are going to carpet it I would use MDO plywood and paint it before applying the carpet. If you are thinking Gelcoat I would use AC fir because it will absorb the resin better. If you need some plywood let me know. If you give me sizes I can even cut it up for you. I work with plywood quite a bit at work and am sure I could find some extra pieces laying around
bustedbrick 09-13-2011 09:35 PM
Backseat
2 Attachment(s)
Here are some pics of the one I am working on. The seat base is one piece and the back is a separate piece. The base is designed to rest against 1/8" x 2" x 2" L-angle Aluminum screwed to the sides of the cockpit. This supports three sides so I have vertical supports screwed/glued to the base to support the middle and the forward edge. I have cutouts in the plywood supports so that water can flow between them during hose-out so it will drain. I really wanted to be able to hose it out so I left a 2" gap between the front of the seat and the floor.
I used 1/2" marine ply. Is $72/sheet which is pricey but it is really nice and straight compared to cheaper ply. I think it's worth it just for that (apart from the waterproof glue used). Also no voids in the middle layers. I plan to glass the exposed edges and joints with a couple layers of glass and maybe a single layer over the rest of it just to seal the surface.
I have built all the pieces shown with 2 sheets. Seat is 78" wide. No upholstery yet, still trying to figure out how to tackle that.
Randy
puzzleboy 09-14-2011 09:32 PM
Just redid all the wood in my sunpad. What do you guys use to seal the wood - regular glass resin brushed on, or an epoxy, or?
Thanks,
J
Thunderstruck27 09-15-2011 12:32 PM
I bet you can get a lot of good ideas and help if you copy this thread to the Fiberglass and Paint forum...just a suggestion.:bigbird: Good luck with your seat rebuild.
jason y 09-15-2011 07:08 PM
here is part of mine i just got done with no before pics but i built it all up in couple nights 3/4 plywood with 2x4s and woodscrews and a good coat of thompson water sealer
its in my 77 255 liberator still have more to recover/build
http://i221.photobucket.com/albums/d...DSC01764-1.jpg
http://i221.photobucket.com/albums/d...DSC01765-1.jpg
http://i221.photobucket.com/albums/d...DSC01766-1.jpg
http://i221.photobucket.com/albums/d...DSC01767-1.jpg
http://i221.photobucket.com/albums/d...DSC01768-2.jpg
http://i221.photobucket.com/albums/d...DSC01769-1.jpg
jason y 09-15-2011 07:10 PM
my back seat is like busted bricks but has 2x4 on edge for the back support be sure to round your edges and corners off with a sander or router before u take to upholstery shop
KEVLARKAT32 09-15-2011 07:38 PM
Plywood is the stone age !!! Starboard board light is what is used on all modern day boats ...................
puzzleboy 09-18-2011 12:17 AM
Where can you buy Starboard?
