-   -   Help with cam and head gaskets (https://www.offshoreonly.com/forums/do-yourself-boating-budget/262337-help-cam-head-gaskets.html)
Artate78 09-14-2011 08:52 PM
I have 454mark 4
3964290 heads Cc 100.9
9to 1 cr
333841 intake
800 Holley dp
1.7 roller rockers
Stock manifolds Gil risers wet through hull
Was wondering whats best head gaskets cometic or felpro marine?
Whats a good cam to go with this set up?
Thank. Aaron
jason y 09-15-2011 07:26 PM
if you have any power adder go with cometics or simlaiar style u have to have a fairly fine finish on your block deck and head for them or chance of water leaking if no power adder any old headgasket would be fine..
Itsallgood995 09-21-2011 01:38 PM
Are those heads stock? A lot of guys say their all done by 4500rpms. I used a 454HO cam in my set up. Picked up about 6mph but also had the heads flowed.
Artate78 09-21-2011 01:44 PM
They have 219/188 valves. What heads or you running
Itsallgood995 09-21-2011 04:11 PM
Oh, my mistake I thought that was the L29 casting. I'm running the 279 Vortecs.
mike tkach 09-21-2011 09:47 PM
Originally Posted by Artate78 (Post 3503787)
I have 454mark 4
9to 1 cr
333841 intake
800 Holley dp
1.7 roller rockers
Thank. Aaron
i use the felpro marine on 99 percent of the engines i do,no failures, as far as a cam,i sugest a hyd roller.
