-   -   Flywheel/flexplate (https://www.offshoreonly.com/forums/do-yourself-boating-budget/262484-flywheel-flexplate.html)
Andrew 19 09-17-2011 02:21 PM
Flywheel/flexplate
Trying to purchase as much as I can for repower before old sbc comes out. #1; How do I tell if I need a wheel or plate?. #2 How to tell if it is 153 or 168 tooth. New bow 1183 tie block. Thanks in advance for all replies. R.
ezstriper 09-18-2011 03:54 PM
merc use 168 tooth manual trans flywheels
picklenjim 09-18-2011 05:40 PM
It's also going to depend on what your building. Will need either internal or external balanced flywheel and harmonic balancer.
Andrew 19 09-18-2011 07:11 PM
F/w--f/p
Questions answered. Thanks again. R.
Andrew 19 09-19-2011 06:54 PM
Flywheel
Any benefits from a lightweight or aluminum wheel ??? Thanks. R.
picklenjim 09-19-2011 07:36 PM
Something I had heard before is you need the heavier steel flywheel or you may have problems with killing the engine when you shift it in gear.
