-   -   o2 sensor (https://www.offshoreonly.com/forums/do-yourself-boating-budget/264449-o2-sensor.html)
winkman 10-20-2011 06:39 PM
o2 sensor
I would like to know if anyone makes a kit to put an o2 sensor in my emi thunder exhaust. I want to get my boat tuned perfectly and am told this is the route to go. Thanks for your help.. Winkman
jeffswav 10-21-2011 10:40 AM
I had them weld in bungs on both sides when I ordered them. I am sure you could ship yours back and they could weld them in for you.
winkman 10-21-2011 12:24 PM
I can weld the bungs in myself...need the sensors and maybe an a/f ratio meter and wiring diagram..
James 10-21-2011 12:31 PM
You can weld bungs in yourself, the tricky part will be drilling through double wall Ss without the bit grabbing. If you can do use a mill or CNC you will be happier
look for O2 sensor (digital) airfuelspark.com simple to use and all in one package
FIXX 10-21-2011 01:47 PM
fixx
fuelairspark.com :drink:
Itsallgood995 10-21-2011 05:42 PM
Do you need the duel setup or is the single OK?
ctriverguy 10-21-2011 05:50 PM
http://www.innovatemotorsports.com/products.php
pretty happy with the lm-2 if you get the inductive clamp you can map to rpm for your application ( i think)
winkman 10-24-2011 06:44 PM
not sure, but i was just going to go with the single... is dual the way to go i guess?
FIXX 10-24-2011 07:27 PM
Fixx
I had this idea for years,,if its a big block and if its a hp style manifold you could remove the intake and drill and tao the center where the exhaust port would between the 2 center intake ports..it will only regesture the 2 center cylinders but its still exhaust gasses that you need to read..
mr3dman 10-25-2011 08:28 AM
Love that idea Fixx! That way you can run without the worry of water killing the sensor. Have you ever tried that? Is there enough gasses flowing through there to register good readings, I wonder.
