-   -   blower shop blowers oil change (https://www.offshoreonly.com/forums/do-yourself-boating-budget/265582-blower-shop-blowers-oil-change.html)
coastlinetrees 11-11-2011 08:26 PM
how do you change the oil in this blower? and how often?
MrSneakAttack 11-11-2011 09:17 PM
which blower? size?
shootitup 11-11-2011 11:22 PM
Originally Posted by MrSneakAttack (Post 3547930)
which blower? size?
Same questions here.... thanks
How, how often, how much, wich oil type..
THANKS FOR ANSWERS !
Mine are 871
http://kuva1.kuvablogi.com/iso/img3342546.jpg
mike tkach 11-16-2011 03:59 PM
to drain the lube,remove the pressure release on the front cover first,then remove the lowest bolt that mounts the drive snout,and catch the lube that comes out.them put the mounting bolt back in,there is a pipe plug near the bottom of the front cover,now add lube until it it coming out of the pipe plug hole,make sure it does not air lock,you can do this by rotating the drivesnout,replace the releife valve,adjust belt tension,clean up any spolled lube,and you are good till end of season.i use amzoil gear lube,but any brand of quality gear lube will work.i forgot to mention the obvious,when you are done filling,replace the pipe plug.
Zoomnfun 11-16-2011 07:56 PM
Dont forget to remove the bearing caps on the rear of the blower and pack them with grease....
