-   -   External Steering......Need Feed Back (https://www.offshoreonly.com/forums/do-yourself-boating-budget/268504-external-steering-need-feed-back.html)
swan2 01-12-2012 09:16 AM
If the dual ram add on is installed now can the other inside for full hydr. be added later date? And if the the dual ram add on is installled without the inside does it still work well until the full hydr. can be done or is this a total waste of time? Thanks for all the input.
US1 Fountain 01-12-2012 04:23 PM
Yes, you can go with the add on now, and then upgrade to full hyd/ at a later date. The add on works in conjunction with the standard PS setup.
ezstriper 01-13-2012 04:00 PM
yes, I have a P/S valve assy for that if you go that route, just took off of mine...
egbolt 01-18-2012 03:21 PM
Thanks to all
GHoing with full single
