-   -   502 Mag MPI HP upgrade question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/268596-502-mag-mpi-hp-upgrade-question.html)
MCKILLOP 01-11-2012 02:08 PM
Originally Posted by Poker~N~Run (Post 3591122)
Efi system is worth a few hundred in real money. Msd 6al ignition box can be bought from summit. Usually can find on Craigslist cheap. Same with dist. I would do it now and enjoy. All compatible with a cam change later.
Just out of curiosity, would there be any benefit in changing the rest of the ignition system? Like a new distributor and coil? Or would the MSD 6M2 ingnition box be enough? Also, would I need a new fuel pump and regulator?
MCKILLOP 01-11-2012 03:51 PM
One more question for you guys, I know its impossible to say exactly, but any idea what kind of HP gains I could expect if I swapped out my EFI for the dual-plane RPM intake and an 800 or 850 carb and an HP 500 flame arrestor? I already have the Gill Offshore exhaust and would also be doing an MSD ignition setup and possibly a fuel pump and regulator if needed?
GTOFFSHORE 01-11-2012 04:25 PM
Private message sent
RdRacerZ28 01-11-2012 07:59 PM
I got your message, I sent you one back with my email address.
Griff 01-12-2012 12:54 AM
Originally Posted by MCKILLOP (Post 3590756)
I am starting to put together a new boat and am trying to do it on a budget while getting every mph possible. I am wondering what, if any HP upgrades that can be done with the motor in the boat? I recently picked up some Gill Offshore wet manifolds with stainless risers, a K&N flame arrestor, an adjustable fuel pressure regulator and will soon be ordering a Mark Boos ECM tune and upgrading my B1 to a BX1. Is there anything else that would be worth doing with the engine still in the boat? I would love a Procharger, but dont really want to dump that much money into a starter boat. Like I mentioned, I have no reason, nor funds to pull the motor this year so a new cam is out of the question for now. Any other options out there for a few extra mph?
All the upgrades you posted might be good for 1-2mph, if you're lucky. Better off to just get your prop labbed and put the rest of the $$ in the fuel tank.
brivander 01-12-2012 08:38 AM
+1
I wouldn't do anything until you can do a cam, well, installing the headers is ok since you already have them...I basically built the carb combination others are talking about here last summer.
For reference here is the carbed combination I had assembled this year.
- Stainless Marine Manifolds (these were already on the boat)
- Rectangle heads with stock valve size and a valve job (matched to intake NOT ported) with Performer RPM (rectangle port air gap) intake and 850 Holley 80330 vacuum secondaries, one jet size down on secondaries
- Converted Gen V 502 Block to roller, honed only not bored -- Bob Madera (RMBuilder) Custom Cam
- Stock JE700 pistons with new rings, stock rods.
- 9.25:1 compression up from 8.75 (.010 off the block and .010 off the heads)
- 1.7:1 Scorpion Roller Rockers
539HP and 569TQ full dress with wet exhaust. Peak power was ~5100
I am sure I left some power on the table -- I specifically told Bob this was a family boat and drive-ability and good idle characteristics were the priority -- he is the man and should be your FIRST phone call, he was EXTREMELY willing to work with me to get the RIGHT combination.
MCKILLOP 01-12-2012 11:58 AM
Originally Posted by brivander (Post 3591798)
+1
Thanks for the advice guys. I think I already knew the answer that question, but was hoping I might be wrong. I have decided to keep the EFI and save my money for a Procharger set up.
Thansk again for the advice, I really appreaite it.
Blueabyss 01-12-2012 12:17 PM
If your motor is running ok then don't do a thing to it. Do not pull the efi. On that type of boat you will do a lot of 2500 3500 cruising and the carb will will prob cut your fuel economy in half. Dumb move. 2 options for speed. 1 have your prop labbed.. Cost is like 400. Speed gain on that boat prob 2 mph. Next is Sell your motor for prob 5000.00 Buy a used 525 for maybe 15000 plus a prop 500. 00. Maybe get 10mph. If your lucky find a used prop for the 525 and have it labbed . 650 total then your up to 13mph for a total out of pocket of 10650.00. These numbers are for example but not too far off. If I were you I think I would go the 400.00 route.
Chris
onesickpantera 01-12-2012 02:38 PM
I also vote for keeping the EFI. When you pull the engine you could swap the cam for a 500EFI cam(or similar) and adjustable roller rockers. Then get the ecm tuned while running the boat. That would be a nice bump in HP.
cigboat1 01-12-2012 02:48 PM
Forget about making the boat go faster,Spend the money on beer and broads
Jim
