-   -   Thru Hull Exhaust (https://www.offshoreonly.com/forums/do-yourself-boating-budget/269317-thru-hull-exhaust.html)
BadBoy 01-23-2012 07:24 PM
Thru Hull Exhaust
Getting ready to cut the holes thru the hull for the exhaust tips. They are 4". How much bigger do I need to make the hole? The outside dia of the tips are 4 1/8". Don't know if I need to go any bigger since it is exhaust. Thanks
Baja226sport 01-23-2012 07:40 PM
You will want to give yourself a little room just so you can fit it together with no problems and you also need a bit of room for a good sealer so NO water can make it's way to the wood in your transom.
If your OD is definitely 4 1/8" I would go 4 1/4". I am not sure there is a hoel saw you can get between them.
blownhammer2000 01-23-2012 10:01 PM
+1 on 4 1/4, i had 4" tips on my baja and there was alittle room for wiggle but not much, also don't forget to seal the tips to the transom, 100% clear silicone works fine for above the water line exit
FIXX 01-23-2012 11:45 PM
fixx
i would buy a 4 1/8'' hole saw,,they are not a exact fit when you bore the hole and they usually end up 4 1/4''
johnny b good 01-24-2012 05:22 AM
For a little more assurance of getting water intrusion in your cut out openings, I would wet them out with epoxy first and let it dry than a sealant/silcone after that.
Knot 4 Me 01-24-2012 08:27 AM
Definitely treat the exposed wood with resin and I would use 3M 4200 to seal the tips.
paul buckner 01-27-2012 07:58 AM
All the above and some seal on all the srewthreads .
BadBoy 02-05-2012 08:31 PM
What is a good epoxy? And where to get it?
FIXX 02-05-2012 09:03 PM
fixx
go yo your local west marine,,all you will need is a&b 1 qt each..
