-   -   Prop Question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/269565-prop-question.html)
GAZ 01-27-2012 08:29 PM
Prop Question
My boat is a 29 Laveycraft with a 500 EFI, Bravo 1 XZ drive it has a 26 pitch Bravo 1 with a flo torque hub on it now, that is supposed to be just right at sea level. I was thinking I would like to get both a 22p and a 24p. Most of my boating will be at 7500 msl. But also will be going to Powell alot (3600 msl). I was looking at props and they come with solid hubs and the flo torque hub. It looks like the flo torque hubs are for 400 hp and less ? I think my boat has about 415 hp. Do I need to have a solid hub?
GTOFFSHORE 01-27-2012 08:37 PM
A 500efi is way over 415hp. What rpm are you turning now? What mph? I couldn't going down to a 22p. You will lose a lot of top end. And those hubs are fine.
GAZ 01-28-2012 07:36 AM
Oops yea the 500 EFI is rated at 470 hp. I'm not sure what rpm or what mph I'm doing. I just was told that it was running a 26 p at sea level (73 mph on gps). Now I'm going to be running at 7500msl and 3700 msl. Was thinking a 22p would be good at 7500msl and the 24 at 3700msl?
GTOFFSHORE 01-28-2012 08:03 AM
They rate it at the prop and they are conservative. You need to get some baseline testing before anyone can truly say what you will need to do. Like I said I can't believe you will need to go down to a 22. I understand you are trying to keep rpm's up but that doesn't always equal performance when you cut here pitch down so much. YOu would pick up 300+ rpm with a 24.
