Gen6 509 build, hyd roller, 764hp, 732tq
I'm re-posting this here. I posted in the general Q&A section, but no one else seems to be albe to see it excpet me. I thought it would be an interesting build...shows the torque potential of something like this with a hyd roller. The cam could be shortened up and bring peak power down some for marine use, but all in all, this is an awesome combination.
------------------------------------------------------------------------ Just got back from the Vrbancic Brother's dyno today with some real nice results. This is for a car, but with the installation of a marine oil pan, a little less compresison and timing, and this would be an honest 740hp/700+lb ft. pump gas 509. It made 746hp @ 6100 and 720ft lbs @ 4800 at 32 degrees total timing....a loss of 18hp and 12ft lbs on the race gas. Gen6 509 4.5 bore x 4.0 str. Scat std. weight crank Engine Pro 6.535 rods Mahle 13cc dome piston, 1.27 ch 11.4:1 cr AFR 305's fully ported (309cc), 2.25 valve, 103cc chamber Straub hyd roller 244/248 @ .05 .649/.629, 107 Morel hyd. roller lifter. Ede. Vic Jr, fully ported , Pro Systems 1000 4150. Corrected (.04) 764hp @ 6200 732 lbs/ft @ 4900 http://www.performanceboats.com/gall...ium/044_2_.JPG http://www.firstgenmc.com/photopost/.../scan00016.jpg |
| All times are GMT -5. The time now is 08:24 PM. |
