-   -   TRS Swivel pin leak! (https://www.offshoreonly.com/forums/do-yourself-boating-budget/271670-trs-swivel-pin-leak.html)
Rambocj7 02-29-2012 02:23 PM
I'm leaking water from both of my swivel pins at top of gimbal pin. There is no play and there are tight. It only started at the end of last season. I'm running full hydraulic external steering, no internal anymore.
Is there a seal there? Where do I get it?
I may end up just getting new swivel pins too. They are the U bolt style.
Richard
picklenjim 02-29-2012 06:32 PM
Looks like your going to need parts 3, 4, 5, 6 in this diagram.
http://www.perfprotech.com/store/ass....aspx#assembly
Hopefully you won't need the swivel pins. Their like $320 each. Part 12 in this diagram.
While it's apart you may as well replace the lower bearing and seals. Parts 2 (2) and part 3.
Be sure to use Merc manual #5 when doing this. The nut which tightens down on the swivel pin against the top of the steering lever lifts the gimble ring to set the up and down play.
Rambocj7 03-01-2012 02:39 PM
Thanks Picklenjim! You've always been a ton of help!
bustedbrick 03-01-2012 07:14 PM
Getting the upper pins out were a serious pain. Both the upper and lower pins made the bellhousing hinge pins seem like a day in the park. Again, lots of PB blaster and heat is what finally got mine out. Good luck, Randy
Rambocj7 03-01-2012 10:20 PM
Actually, does anyone nhave merc manual #5? Or the precise instructions needed to tighten that nut?
picklenjim 03-02-2012 01:02 PM
I have the manual in both hard copy and PDF. PM me an email address and I will try to send it to you. It's 57MB which is too large to send regularly so I will have to send it through some type of compression program.
picklenjim 03-03-2012 11:31 AM
Caution there is a Mercruiser Highperformance Service Manual #5 for #Vl Dry Sump Stern Drives. This is NOT the one you want. You need Mercruiser Servise Manual #5 for TR/TRS Stern Drives.
[email protected] 03-03-2012 07:02 PM
What do you use to get the upper pin out?better yet what is the procedure to getting it off, I've got the lower one out !
proboat-wes 03-03-2012 07:27 PM
a mercruiser specialist can help do this right,alots at stake if the boat takes on enough water and the bilge doesnt work right then insurance denies the claim.i deal with this everyday
[email protected] 03-03-2012 08:15 PM
Mine isn't leaking I just need to get it off so I can put a new bushing in the bottom pin!
