Here's the New 502! Looking for 625HP
Snapmorgan:
Just curious here with your results.
Could you please post some specs on your 540 build? Something seems kind low there for I believe a good mild build 540 inch engine should produce more than 565HP , more like 600-625HP. Maybe you could list the specs. such as heads, camshaft, intake system, exhaust, compression etc. Would be a help possibly to you and others here on OSo trying to achieve their goals.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
But the Holley HP system has outputs for NOS, Fans, etc....
I've installed a 1" 12 volt valve that the holley systems will active at 1100 RPMS and below. Dumping most of the water (not all) at idle speed, between where the header transfers water to the tails. testing the temp, and sizing the hose after the valve will control the amount of water that stays in the tails. This will help save the engine and the O2 sensor.
BC
Was this fountian at one time sitting off of Pine Forest Rd under a metal car port? Hope you make it to the run on saturday. I bet that 502 is gonna sound sweet.
LC
LC
The tails are wet at the transom.
BC
BC
Regardless good luck those heads are beautiful.
Snapmorgan:
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
540CI
9.2-1 compression
Madara cam .621 lift 236 in dur 240 ex dur
Edelbrock marine heads 315cc (stock)
2.25"/ 1.89" valves
6.385 rod length
Imco power flow exhaust
502Mag EFI intake, ported and extrude honed
Bored out throttle body from 60mm to 69mm
Mefi 3 electronics
Made 567hp and 633# tq
Respectable numbers for out of the box parts that anyone can build, just a little lower than I was hoping for. Next time the heads will get ported or replaced and probably a Holley EFI setup.
But I also have to keep in mind that this was not a max effort build. it was designed around the injection system that I had and to keep my bravo drive alive. I just got a little greedy towards the end. Always wanting more i guess. It will probably wear out before it blows up though.
Snapmorgan:
Thanks for the specs and the information. I would say from the torque number that the camshaft, heads and compression are doing pretty fine. The big problem is the intake manifold and throttle body, believe me when I say that even extrude honed and bored throttle body your intake setup is choking off the power big time!
Either get yourself and 500EFI or 525EFI take off intake and throttle bodies or the Holley type set up and I guaranty you will see the extra 60HP you're missing and not a great deal more torque so I don't think it will be a drive killer driven reasonably.
Just remember engines are air pumps that burn gasoline to make power, choke off air into a well built air pump (engine) and it will not make good power. Best of luck with future improvements and have fun. Get yourself and good intake system when you can and that added power will be very much appreciated.
Best Regards,
Ray @ raylar
Best Regards,
Ray @ raylar
