Vinyl...one thing leads to another!
So I have been having problems with the electric engine hatch ram on my 21' Chris C. I have heard of waterlogged seats/wood causing these things to slow to a crawl...so just for giggles I pulled the lower seat...wet foam and wood, same with the upper swim pad backing. I unstapled the vinyl and found the inner liner fabric of the vinyl is spotted, stained and nasty...though the outside looks ok. My plan is to clean and dry out the foam and cut new wood, not a problem. Is there any way to save the vinyl? its not perfect, but I wasn't planning on a full recover job this season...any thoughts? ----Rob
if you unstapled it, you can restaple it. resewing it is impossible though. paint the wood, both sides. wrap foam in heavy plastic before replacing cover.
Originally Posted by dereknkathy
(Post 3654581)
if you unstapled it, you can restaple it. Resewing it is impossible though. Paint the wood, both sides. Wrap foam in heavy plastic before replacing cover.
I wouldn't wrap the foam in plastic, IMO it won't let it breathe if it gets damp and might mold. Also don't let the vinyl loose its shape while your doing the work on the wood and foam. try to pack it with something, paper or raggs while their sitting so they don't shrink up. Just my 2 cts.
I'm about 60% done with a full interior redo. do to old age,water log, and weather cracks.
I mainly do interiors for auto's but am no stranger to doing a boat interior. 1. You unstapled, makesure you have enough fabric without little pin-holes from old-staples 2.milkey spores,mold etc is in the foam....spray with (bleach 75% mix 25% water) but i would just replace the foam!!! hint hint. 3.Never bag foam.."FIREBOATPILOT" 100% right 4.If you cut new wood which i no u will..i always expoy the edges and then use a nice marine paint on the surfaces. then wrap with foam then..in your case reuse your covers. Best of Luck- |
there are diff schools of thought on bagging the foam. in every case, the foam is waterlogged and wood is coming apart. did the vinyl keep the water out? obviously not. did it let the foam dry and breathe? once again, obviously not. the vinyl slides over a layer of plastic a million times easier than it drags over the foam as you install it. boat manufacturers do not wrap the foam. it will last the warranty. they also don't paint the wood-except where it shows.
Thanks for all the feedback. Decided not to re-use the vinyl, going to have it patterned and the covers done by a pro. Going to tackle the foam and wood myself, which I have done in the past. Picture my engine hatch ( which includes the sun pad and rear bench) as a big fiberglass bathtub that holds the seat inserts. There are a few drain holes underneath, but they were clogged with 15 years of crap. I guess even with the best maintenance, stuff eventually breaks down. To me it's a design thing that looks good on paper, and well, you know the rest..haha. It wasn't hard to pop the seats out...sounds like maybe an every other year thing for cleaning. But then again, I don't usually keep a boat long!---Rob
| All times are GMT -5. The time now is 03:00 AM. |
