-   -   Livorsi control install question? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/274316-livorsi-control-install-question.html)
MCKILLOP 04-12-2012 11:04 AM
I am getting ready to swap my oe offshore control for a billet Livorsi control. I believe the oe one is just the stadard Kiekhaefer control? Anyways, I am a little worried that I am going to have trouble getting the new throttle adjusted correctly, or should I be able to unbolt my oe control and bolt in the new one? I am fairly mechanically inclined, but I have never pulled pulled controls before. Should I just have it installed for me? Or is this somethign I should be able to do myself?
Old control-http://i628.photobucket.com/albums/u...1/Dozihelm.jpg
New Control- http://i628.photobucket.com/albums/u...c1/control.jpg
Griff 04-12-2012 12:29 PM
They are easy to adjust. You can get them pretty close at the control and then do the final adjustment at the other end in the bilge.
Meara_Image 04-17-2012 07:51 PM
nice conrtol! same size as your o.e? as far as mounting base goes. that's the only problem i see, should be almost plug and play as Griff stated.
MCKILLOP 04-18-2012 12:43 PM
Pictures are deceiving. Same size base and mounting holes.
Meara_Image 04-18-2012 06:03 PM
Go to it! and keep us posted!!! what a face lift it will be from the o.e controls!!!
MCKILLOP 04-18-2012 08:55 PM
Thanks. I have the matching wheel and gauges installed as well. Should look a lot better
Rookie 04-18-2012 09:20 PM
Did you purchase the red and clear switch covers?
Meara_Image 04-19-2012 01:25 AM
I was going to say a wheel and some gauges would look SICK to go along with that shifter!! Wise choice to add some color! I'm digging it!
:musik010:
