Low oil temps , milky Oil
Ok heres the deal 97 fountian with carb 454 mags , Took it out yesterday and never got oil temps over 140even after a hard run , just bought this boat last fall and have not checked to see if the thermostats have been removed the boat came from down south so maybe , what temp tstats should this motor have in it ? and do you guys have any ideas ...
140* milky oil,, did you winterize it when you brought it up from down south?
yes both motors where winterized, and i noticed this last year before it was put up for the winter nap.. just now getting aroung to checking this out..
Originally Posted by speedfreek1
(Post 3681715)
would putting in 180 * stats help any? Im thinking if i can raise my motor temps in turn I will raise my oil temps, both motors are running low temps, prob also in the 140 range and a lil lower ...
(Post 3681758)
Is your oil milky and foamed up? Or do you just have oil/condensation on you oil caps or breather?
My old merc 420's would have condensation on the caps and breathers if I was in cold Lake Mi and did not run it hard for a while. When I had a head gasket going, then I had milky/water in the oil. |
I'd change that oil before I did anything else, then check if thermostats are fitted. 140 should be enough to boil any water out of the oil, so I'd be very concerned about it's condition.
Originally Posted by rsparso
(Post 3685768)
| All times are GMT -5. The time now is 07:13 PM. |
