Originally Posted by mrfixxall
(Post 3701153)
+1... i have also seen in the past that the bottom bolts/studs rust in half but i have a feeling that your going to find some rot also..torque them to 30 first then to 57 ft lbs and go over them more then once..
Thanks for the torque specs . |
Originally Posted by blefever
(Post 3700711)
Gimbal bearing in backwards?????? Please explain.
Originally Posted by dereknkathy
(Post 3701167)
the gimbal bearing has a cage. the bearing outer race swivels in this cage. there are 2 slots cut in cage so that bearing can be flipped sideways and removed without slide-hammering the cage out. fact install puts the slots on the inside just to be mean. put slots so you can see them when looking in from the stern thru gimbal boot.
Next time the bearing needs replacing (most likely by some other owner of the boat) he can just flip the bearing sideways thru the boot and replace the bearing with out slide-hammering the cage out. Is this correct? |
I second the check of the water intake tube, very common problem on bravos of your age. More common than transom rot. I beleive you are still going to have to pull the engine to replace this tube however.
Job is fairly simple, however it is the room that makes it tight. Remove drives. I suggest completely removing engine hatch. Remove exhaust tubes. Remove ground wires, backs and sides of engines. Take out startboard first, remove power wire, unhook merc plug, unbolt front mounts and remove two long bolts on rear bellhousing mounts. The rears are 3/4 head sixe and best removed from the top with long ext. The back bolts have springs around them, don't lose them! These back bolts are used for drive alignment. Now do the same with the port engine, the reason for taking the port out last and installing first is for easier access to the power wire on the starter. While out replace or have starters rebuilt. Inspect flywheel gear, inspect or replace couplers. Replace impellars.....all very easy jobs with engines out, and PIA with engines in on that boat. |
(Post 3701201)
So the new bearings come with a new cage? or do I reuse the existing cage and just turn it around so slots are to the rear?
Originally Posted by 4bus
(Post 3701372)
(Post 3701426)
yes. bearing comes with cage. if you see the slots looking in thru boot, they have been changed and are now correct (backwards is correct in this instance.) take a long extension or giant screwdriver. put it to bearing right halfway between slots as far outboard on bearing as you can get it. knock it sideways with a hammer and pull it out the slots. FIRST stick fingers in bearing and turn it. if it feels perfect, it probably is...
Good information, Thank You. |
one important detail if you change bearings this way. there is a hole on outside of bearing race that grease goes into. there is a slot in the cage that grease goes to to feed the hole. THEY ARE OFF CENTER!! feel for the slot in cage. i am pretty sure it is toward the slots. when you knock the cage off the new bearing check it out and you sill see what i mean. make sure where that hole is. if you spin the bearing in with hole not aligned with slot, bearing will never get any grease.
I think the new bearings aren't greasable
Originally Posted by seafordguy
(Post 3701671)
Think about it they put non greasable bearings in autos for decades and they run for thousands of miles with no problems. |
| All times are GMT -5. The time now is 02:09 PM. |
