How to make this work?
2 Attachment(s)
I have a 1990 454 Magnum Gen IV motor. It had the old six hose thermostat housing which had the balls and fed the risers and the manifolds. This spring I upgraded exhaust to EMI's and added the thermostat housing which is found on the Gen VI motors with the four hoses. Just two that go to manifolds. Has anyone ever experienced water flow problems when adding this newer thermostat housing to a older motor and what did you do to fix the problem?
heat exchanger, or raw water? with new style you are limited to raw water in your new manifolds, anti-freeze in engine only.
the old housing had hoses going from the housing to the exhuast manifolds and from the housing to the risers you would need to delete the riser water fittings and plug them and make sure you have the correct riser gaskets. im guessing raw water cooling .
Shouldn't be any issue at all.
The EMI's should have the hose that goes from the manifold to the riser. All you need to do is do the plumbing from the thermostat housing to the bottom of the manifold. http://www.eddiemarine.com/xl/EMI-511.jpg |
Originally Posted by scottw
(Post 3704339)
Originally Posted by dereknkathy
(Post 3704408)
Originally Posted by Griff
(Post 3704570)
The newer style has an internal bypass system. You just run the hoses from the tsat housing to the bottoms of the manifolds. What kind of problems are you having????
Incorrect.......again. |
Where did you put the thermostat?
Did you put it in the intake, or into the new housing? Did you line up the blue or white spacer gaps properly into the new housing? There are two spacers provided, one for having a machined groove in the intake for the thermostat, the other shorter for a non machined groove intake. Just in case you are not aware, the stackup is intake, spacer (proper one) and aligned, then thermostat. If you turn the new thermo housing over, you should drop in the thermostat, then push in the spacer, the spacer has a tiny nub that fits a machined notch in the housing so you get it aligned right, then flip the housing over and install onto the intake. I purchased these for my rig, and made the mistake of putting the thermostat into the intake, I didn't look at the exploded diagram for stack up until looking on line at Merc parts diagram and then it hit me. I had to look on line because the same "no flow" through the block occurred to me. I had the stack up wrong. Gosh I felt dumb. Once installed properly, it works perfectly. |
Originally Posted by 88Fount33
(Post 3704706)
I have done just exactly what you want to do. I have ran it for a couple years with no problems. If you have stock manifolds you need to plug up the riser and only send water to the bottom of the manifolds.the water will go up through the riser and exit. Make sure you have the tstat in correctly with the correct gaskets. I run 160 tstats and no issues !!
fixx
you need 140* high flow thermostats,,97 gallons per minute....if you dont have the thermostats in the correct part of the housing and make sure they are NOT in the intake manifold or else your going to have erratic readings.. it gors from top to bottom,,thermostat housing,then thermostat,thermostat spacer with the small part of the divider facing forward then the gasket..if the divider is not facing forward then you will have lots of water steam problems..
alot of people dont realise that theirs is a differance in how much water a normal thermostat flows which is like 57 gallons per minute..order a set of thease and have a nice day! http://www.hardin-marine.com/p-14347...hermostat.aspx |
