help with cam size 454
i have a 454 .30 over with 9.5 compression. air gap dual plane intake. 496 exhaust 049 heads. 750 holley carb
what cam should i go with? |
Contact Bob Madera at Marine Kinetics. He will set you up.
You know its funny i was going to make a post like this, and almost every time I search for cam spec info the same thing comes up - call bob madera.
I guess i will give the guy a call |
This is what I had built before. A very good motor.
*1986, MIE/340 (7.4) 454 Big Block Dip it and hone the decks and cylinders (the cylinders did not need to be cut and are standard bore) Block was detailed with all casting debris removed Stock seasoned crank (also cleaned up) Reconditioned connecting rods ARP Rod bolts .210 Domed Speed pro pistons and pins. (They should give me 9.38 to 1) Molly piston rings Federal Mogal bearings (cam, main & rod) Cloyes true double roller timing chain Moroso Chevrolet 454 Stud Girdles #6729 BBC Crane #132561 hydraulic cam--Duration Advertised: 298° Intake / 306° Exhaust Duration @ .050'' Lift: 228° Intake / 236° Exhaust Valve Lift w/1.7 Rockers: .530'' Intake / .551'' Exhaust Lobe Separation Angle: 114° Crane #99277 lifters Comp Cams High-Tech pushrods #7954 Completely refreshed Chevy 14096188 heads / 454 Open / 118cc / 3angle valve Comp Performance Valve Springs #911-16 Pioneer head bolt sets ARP 1.90 rocker studs Norris S/S 1.7 roller rockers Melling H/V oil pump Melling HV oil pump shaft. EDELBROCK BBC R2 AIRGAP INTAKE JEGS 15951 - Mechanical Fuel Pump Pro Comp Ignition Pro Comp distributor Super Stock coil 8mm Accel Hi performance wires New single wire alternator Mini (gear reduction and fully marine) starter Edelbrock 800 carburetor 12" aluminum, oval air cleaner (with K&N filter) Brass freeze plugs Stainless steel bolt set 4” Stainless steel risers GLM aluminum exhaust manifolds Sherwood motor mounted raw water pump. I took that motor out and built this one to replace it with, 1987, MIE/340 (7.4) 454 4 bolt main Big Block Dip it and hone the decks and cylinders cut .060 over Block was detailed with all casting debris removed Scat 9000 Crank 4.25, 496 stroker Scat 26385P - 6.385 in. Connecting Rods - Bushed -I Beam Forged 4340 steel Howards Cams 120255 - Max Torque Retrofit Hydraulic Roller Camshafts, Hydraulic Roller Tappet, Advertised Duration 288/294, Lift .585/.610, 112 L/S Howards Matching Valve Springs 98636 - 130# / 330# Cloyes Gear 9-203 - Cloyes Wear Plate, 031 in. Thick, Maxspeeding Hydraulic Retrofit Roller Lifters Probe 496 Dome Top +18.0cc - SRS Piston Set Clevite 77 Cam Bearings Federal-Mogal 4400 M20 Main Bearings King Engine Rod Bearings CR849HP Cloyes true double roller timing chain Mahle - Plasma Moly Coated piston rings Melling 10778C (Anti-Cavitation) oil pump Melling HV oil pump shaft. New Harmonic Balancer Rotating Assembly Fully Balanced Comp Cams High-Tech pushrods #7954 Completely refreshed Chevy Heads 14096188 / 454 Open / 118cc / 3angle valve APR head bolt sets ARP 1.90 rocker studs Norris S/S 1.7 roller rockers Seal Power Gasket set EDELBROCK BBC R2 AIRGAP INTAKE Pro Comp 2752 Fuel Pump Pro Comp Ignition Pro Comp distributor Super Stock coil 8mm Accel Hi performance wires New single wire alternator Mini (gear reduction and fully marine) starter Edelbrock 800 carburetor 12" aluminum, oval air cleaner (with K&N filter) Brass freeze plugs Stainless steel bolt set 4” Stainless steel risers 496 MerCruiser exhaust manifolds with Tall Risers Sherwood motor mounted raw water pump |
My boat had this cam in it before it ate up the crank http://www.compcams.com/Company/CC/c...?csid=404&sb=2 Probably a little small, maybe not though i also had 049 heads like you did
Is that the only information you want to give us to answer your question?
You want cam specs for a 9.5:1 454? What's it in? How do you plan to use it? What are your goals? If it's in a houseboat, I'm recommending something different than if it is in a 22' lightweight vee, and something else again if it is in a 17' jetboat. MC |
Originally Posted by sonicss42
(Post 3716512)
contact bob madera at marine kinetics. He will set you up.
First question on cams is What Exhaust are you running?
