Help, Engine cuts out at high rpm on 6.2 MPI
07 Donzi 28zxo with twin 6.2's
Port engine kicks out at around 4500-4600 most of the time and its like a light switch. Its off then drops back 500-700 rpm then comes back to life then once back to 4500 rpm back off then back to life and so on and so forth. If I back throttle down by two hundred RPMs to say 4300 the motor runs great. Starboard motor runs and pulls non stop as hard as it can. I can have the port flat out sometimes and its fine but its rare and short lived. I have installed all new plugs, wires, cap, rotor, swapped distributors, new fuel filters, checked for anti siphon valves, pulled fuel lines to inspect, and replaced the map sensor due to a random code. I have fuel pressure around 38-40 with key cycled on, with engine running its around 35-36. Up to speed it drops down to in the lower 30's say 33psi. I have read that the pressure is not to exceed the 40psi mark so I do not see that. Also, I seem to sometimes get backfires through the throttle body at lower cruise speeds, when motor is under more strain, coming up on plane, but not up and running. At least I think, its hard to hear at 60+. Oil pressures are great, cooling is great, and you would never know that a thing is wrong other than occasional backfire and the top end issue. I always run good gas, use either quicksilver fuel treatment or star tron. It hasnt stopped us from using the boat, but its nice to own a Ferrari, but not with the valet key. Anyone have any ideas........ I was thinking of swapping the fuel pressure regulators from the engines next to see if this makes any difference, but figured I would shout out to see if anyone knows anything more. Thanks for your help if you have any to give |
I had the exact same thing happen to me a few years back. Ended up being the injector harness at the #7 cylinder. With the boat running pull push move every wire, start at the front and work you way back.
Someone else had a similar problem and I think it was a loose wire on the starter solenoid, do a search there is a lot of info on here about the 6.2s |
Originally Posted by Expensive Date
(Post 3743963)
Someone else had a similar problem and I think it was a loose wire on the starter solenoid, do a search there is a lot of info on here about the 6.2s Also, this motor was replaced due to a spun main bearing since the previous rich owner didn't care to keep up with his maintenance, care, etc.. We replaced the engine with a Jasper re-manufactured motor at the beginning of the season after going through the whole boat, transom, drives etc. and cleaning everything to get it back in A+ shape. Absolutely love the boat, but want it fixed right at least once before the end of the season. Unsolved mystery continues......... |
just some ideas
Your issue sounds like a lean out condition, back firing, runs good to 4200 or so, runs good after backing out of throttles....
you should check the injectors for resistance. They should all be within 1-2% of each other. FP is low WO Pressure should be closer to 37-38, try disconnecting the vacuum reference line and test. how do the plugs look |
Originally Posted by tunertech
(Post 3744071)
you should check the injectors for resistance. They should all be within 1-2% of each other. FP is low WO Pressure should be closer to 37-38, try disconnecting the vacuum reference line and test. how do the plugs look Plugs looked good when removed and installed new ones since they were out and wanted to rule them out. I plan on swapping the Fuel Pressure Regs this week, and retest with fuel pressure gauge this weekend. Going to have someone record the gauge throughout power range to see if it spikes or loses pressure at WOT. Im going to test both engines so I can get a good comparison. I will check the the injectors and are you refering to the vac line that runs to the Reg? |
Swapped regulators today from the fuel rail, and cycled both engines and pressure primed to 42PSI then dropped back to 39-40. Let sit and pressure dropped little over time to 35psi. Ran both engines on hose, started and idled fine, warmed them up, and had good throttle response from both engines one at a time. Both fuel pressure reading mimicked the other. No difference in either while idle or snap of throttle. Also removed the flame arrest-er, inspected the TB, butterfly, and removed the dirty foam muffler from the port since the starboard was already MIA. So now they both hiss like a pissed off pit viper. I also checked the Crank sensor since I read a post about that, it seems to be fine, the plug is in good shape, snaps in tight, wires look good.
Will do test run in water tomorrow to see what the fuel pressures are at WOT. I'd be willing to pay to get it fixed since obviously I am not having any luck, but so far nobody can nail this one down. I've spent so much money this year on this boat, and it would be awesome to get this fixed and have it run right at least once. :readinghelp: |
Originally Posted by BradmanVA
(Post 3745490)
Will do test run in water tomorrow to see what the fuel pressures are at WOT. I'd be willing to pay to get it fixed since obviously I am not having any luck, but so far nobody can nail this one down. I've spent so much money this year on this boat, and it would be awesome to get this fixed and have it run right at least once. :readinghelp: This sounds so much like mine a few years back, keep in mind we are just throwing ideas out but one guy on hear had a broken pickup in the fuel tank. If it is a fuel problem that could be it. |
fuel pressure at 1800 rpms should be 43 PSI.
OK, filled up and ran star tron treatment.
Upon initial start up and run at the docks both motors ran well. Fuel pressure gauge was hooked up to port motor since I switched the regulators. Pressure primed to 42 then back to 38 running. Left the docks and through the no wake zone with no issues either motor. Went to get up on plane and heard the same popping through TB, but once up and running seemed to be running fine. Started out cruising out of the creek at around 35 then cleared the creek and started to run the boat up to speed. Seemed to run all the way up to full RPM's for a brief 2 minute until the initial problem started where port started kicking out. Fuel pressure was steady throughout even when high rpm problem started acting up. Then all of a sudden the starboard motor sounded a guardian alarm of two beeps every minute and I brought the boat to a stop in the water. When cutting back on throttles the boat settled in the water and the starboard engine stalled. This was puzzling, but I restarted it and had to give throttle to keep it running. I tired to back it down to idle again only to have it stall again. So, I figure that the fuel pressure regulator that I swapped had to have caused this new issue on the starboard side motor since I have had no problem with this at all except cold starts. The thing that does not make since is that I still have the same port issue, but have now created another issue on the starboard also. After a brief stop, went underway again with guardian alarm still beeping twice every minute till reaching our destination 10 minutes away. We anchored up and I raised engine hatch and switched the fuel pressure gauge to the starboard motor to get a comparable fuel pressure reading on the return trip. We enjoyed the day, and loaded up to leave. Upon the return trip the starboard motor would not run above 3000 rpm without the guardian alarm sounding at constant beep. If i kept the boat on plane with the port motor just long enough to drop the starboard motor to around 1K rpm the constant alarm would go off and I could resume power on it as long as I did not use more than 3K. Starboard motor was in Guardian protection and port was even dying out at lower RPM due to the strain on motor causing the cutout at even lower than 4500. Now it was dropping out below 4K. Fuel pressures seemed to maintain on starboard motor as well but due to guardian I could not get a WOT reading. So Port still has the cutting out issue, and now Starboard has its own problem since the swap of the fuel pressure regulator. I guess the fuel pressure regulator is bad, but obviously is not the fix for the ports entire issue. I flushed the motors at home and when I removed the vac line off regulator the starboard motor would actually idle. CRAZY..... I do not want to touch anything till I can scan the computer to see what the codes/failures are. I am waiting to hear from my boat tech today so hopefully I will have more news later. Im so pissed off and frustrated........ |
IAC valve is bad, possibly a totally separate problem.
(Post 3746538)
So right you are! I swapped those from one motor to the other earlier since I didnt hear the pissed off viper anymore coming from that motor. Wont even move to open. I tried to go buy a marine unit, but nobody was open or had it. So i did some further investigation and was able to find the same identical part, just not painted in automotive brand. A paint job and 2 minute install later that problem is fixed (gonna keep an extra one of these around for future). Mercrusier part number 862998 Advance (BWD 50550) Car Quest (734874) The only difference was the addition of a spring inside on the shaft and the shaft went all the way to the top instead of only half way. Im sorry but I should have taken a picture. Idle is Fixed! YEAH OK, so in the meantime while I was running around chasing parts, my tech found the large fuse (square block with U shaped metal fuse inside) that was corroded and had been arching that was located near the trim pump motor. He said that it supplied power to all the accessories, ecu, etc.. Thinks it may be the entire problem with the high end, but would need to replace to know for sure. I had already had to replace the one on the starboard early in the season since I could not even get my trim pump motors to work. I wasn't surprised to see this one in the same condition. I think from now on when I find something bad like this I am going to automatically replace it on the other side as well. So, until next time, maybe Wednesday I will have another update. Thanks everyone so far for your help and hopefully I can help someone else by giving good notes on my issues. |
OK, Well IAC is replaced and the main fusible link. We put it into the water and still had popping through starboard motor TB, and once it warmed up the port motor would still kick out at high RPM. Im just fed up with this issue and ready to take it to someone that can knock this problem out!
Who knows a technician that is awesome? Close to Hampton Roads? I will take a day off and tow it to you if I can get this problem fixed.... I have a Land N Sea account so parts are no issue. After the replacement of the fusible link/fuse we had a problem with the port side tach which is a new issue. So now the tach is intermittent also, I just want a master tech that I can count on for assistance or problem solving! Diagnosis shouldn't be a CRAP SHOOT........... Needing help understanding my issue ????????
I can run it still, but scared of damaging the engine with backfire and such which is most likely lean running issue (under load). I love my boat, but I am scared of enjoying it with issues . I have spent over 23K in parts and labor since Feb. Someone please help me get this straight, I am getting to the point of being tapped out on time and money. Anyone............................................ ........... :readinghelp: |
Check for a cracked fuel pickup in the fuel tank before you spend a bunch of money changing parts.
maybe try switching fuel lines at the tank. |
Try spacing the Crank pos sensor away from the reluctor wheel apx one # 10 flat washer thickness will do.If it gets close it does wierd stuff. hf...
I will try both of your suggestions....... I will let you know how it turns out. I wish i could get my hands on a laptop with software to really see all aspects of the issues.
THANKS FOR HELP FROM EVERYONE SO FAR!! |
You smoked your iac then that smoked your ECM!
ANY updates? Having same issue
Any update having same issue donzi zx 28 mercruiser 6.2 wont rev past 4000
| All times are GMT -5. The time now is 06:07 AM. |
