-   -   EFI 502 VST bypass? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/282780-efi-502-vst-bypass.html)
whiskeyhangover 08-14-2012 09:09 AM
EFI 502 VST bypass?
is there any way to bypass the VST?
Steve H 08-14-2012 11:34 AM
Goodmorning Whisky,
It is relatively easy to do by running the fuel return directly to your fuel tank and buying a standard high pressure fuel pump to feed the rail. There are several threads on this very subject. If you do a little searching you will find plenty of info. I did it several years ago, and it's still working fine.
Steve
1BIGJIM 08-14-2012 12:00 PM
Yes - Not to be a wise guy, do a seach this has been covered 100's of times.
