my 2 cents
Prop is too big. I have a 24' Python (much lighter boat) with a 625 hp 540 cid motor. After trying many props, my boat likes nothing bigger than a 26 p three blade. I can turn the 26p to 5500 with lots of trim, but with more pitch than 26 the rpms drop dramatically.
Originally Posted by Scarab28
(Post 3760591)
I would try borrowing a 26" B1 just in case, takes a lot to spin a 28".
Originally Posted by Flying Tomato
(Post 3760693)
you need a 25 mirage + for that boat to even get the nose out of the water..that boat would rock with RT HAND REVOLUTION PROP..http://www.ebay.com/itm/NEW-Mercury-...#ht_2343wt_962
well took it out this weekend and fuel didn't change still 4000 rpms. So this weekend we are going to try some props. A buddy said he has a 25p three blade.
Also I think my oil for the outdrive trim pump needs flushed. the oil foams up when we try it running. I am pretty sure it isn't trimming up while running. When we changed the pump from the old reservoirs they had nasty muddy oil water whatever in them. So we are going to clean it and try some props. |
Originally Posted by 86Capri
(Post 3763001)
Well took it out this weekend. I believe you are right about needing to rebuild pump we tried flushing and it is still air-rating the oil. But a local marina loaned us a 26p 3 blade turbo something prop. Which allowed the motor to turn 5200 with trim all the way down. But this prop didn't look like anything nice which pushed to boat only 57mph . It was horrible on plane and the motor seemed like it wasn't even trying. Thinking maybe 25p rev4.
(Post 3768671)
looks like a lava lamp when it starts then just turns real light color. Lots of little tiny air bubbles. after a few minutes let it settle, looks perfect again.
(Post 3768836)
| All times are GMT -5. The time now is 03:21 PM. |
