-   -   502 efi crankcase ventilation question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/283154-502-efi-crankcase-ventilation-question.html)
prostock85 08-20-2012 04:11 PM
ok, 94 502 efi What is the proper way to have these vented. Mine has 2 open pcv's (no hose, leaks oil) and two cheap metal moroso vents. These are stock valve covers. How are these supposed to be run and to where? Thanks
HiPerf2000 08-20-2012 09:03 PM
on my efi's the stbd side valve cover hole is directly under the air cleaner. the fitting there is a "T". the top is open so it blows into the air cleaner. the port side hose runs under the plenum over to the stbd side "T" fitting.
prostock85 08-21-2012 04:32 AM
Thanks. I can understand how that works, unfortunately I have no occ holes in the vicinity of the air cleaner. Any suggestions?
http://i99.photobucket.com/albums/l3...25C55E8624.jpg
http://i99.photobucket.com/albums/l3...25C0CF0A77.jpg
http://i99.photobucket.com/albums/l3...25BB5C2724.jpg
