Which 496 kit
Blew the motor Sunday, so planning on rebuild wondering which
Brand Stroker kit would be best? Or reputable |
Sorry to hear that! Wish I had some advice but this is out of my area of expertise! I'll be following this thread though because I'm planning a rebuild in a couple years and "love a good stroking".:thankyouthankyou:
Build your own.
1987, MIE/340 (7.4) 454 4 bolt main Big Block Dip it and hone the decks and cylinders cut .060 over Block was detailed with all casting debris removed Scat 9000 Crank 4.25, 496 stroker Scat 26385P - 6.385 in. Connecting Rods - Bushed -I Beam Forged 4340 steel Howards Cams 120255 - Max Torque Retrofit Hydraulic Roller Camshafts, Hydraulic Roller Tappet, Advertised Duration 288/294, Lift .585/.610, 112 L/S Howards Matching Valve Springs 98636 - 130# / 330# Cloyes Gear 9-203 - Cloyes Wear Plate, 031 in. Thick, Maxspeeding Hydraulic Retrofit Roller Lifters Probe 496 Dome Top +18.0cc - SRS Piston Set Clevite 77 Cam Bearings Federal-Mogal 4400 M20 Main Bearings King Engine Rod Bearings CR849HP Cloyes true double roller timing chain Mahle - Plasma Moly Coated piston rings Melling 10778C (Anti-Cavitation) oil pump Melling HV oil pump shaft. New Harmonic Balancer Rotating Assembly Fully Balanced Comp Cams High-Tech pushrods #7954 Completely refreshed Chevy Heads 14096188 / 454 Open / 118cc / 3angle valve APR head bolt sets ARP 1.90 rocker studs Norris S/S 1.7 roller rockers Seal Power Gasket set EDELBROCK BBC R2 AIRGAP INTAKE Pro Comp 2752 Fuel Pump Pro Comp Ignition Pro Comp distributor Super Stock coil 8mm Accel Hi performance wires New single wire alternator Mini (gear reduction and fully marine) starter Edelbrock 800 carburetor 12" aluminum, oval air cleaner (with K&N filter) Brass freeze plugs Stainless steel bolt set 4” Stainless steel risers 496 MerCruiser exhaust manifolds with Tall Risers Sherwood motor mounted raw water pump |
Sorry to hear that, was this after I saw you at 2 Georges? Where were you when it let go, how bad is it?
Ya on the way to peanut the block cracked in one cylnder, so no more boring ideas. Im planning on a 502 build since i have to start from scratch..
Originally Posted by pantera232
(Post 3770376)
Eagle and scat make a good forged kit for what you need.
fixx
Originally Posted by rchevelle71
(Post 3770693)
That sucks!!!! If your already going 502, might as well go 540:evilb:
Originally Posted by f_inscreenname
(Post 3768363)
Build your own.
fixx
Originally Posted by bert4332
(Post 3772916)
How much was the cost of the rebuild?
Originally Posted by mrfixxall
(Post 3772974)
do yourself a favor and stick with forged..will not brake the crank like cast stuff..
As for cost, you will have to goggle that. Thats what i do. Find what parts and numbers needed and then buy them from the cheapest sellers. I've bought crank, rods and pistons all from different sellers before because of being that much of a price difference between sellers. |
What kind of hp did this build make?
Looks like that makes 2 of us. From what I see arent you better off going 489 .03 over instead of 496 in case you ever needed to rebuild again??
(Post 3768363)
Build your own.
I would stay away from Eagle cranks. Know a few friends that have had good luck with Scat up to 650hp.
When you start getting into 4.25+" stroke cranks Cast should be avoided because the amount of webbing or crank rod journal overlap starts to be critical, even at 600 hp IF it were to detonate it could still break with no warning, your only talking a few hundred dollars more, Smitty
Originally Posted by miller high life
(Post 3773636)
What kind of #'s does this produce & at what rpm's?
So i found a 454 short block at daddysos marine in pompano near me. bored out .30 with some domed piston and a stroker crank, still getting the details, but it does have a steel crank studded and aftermarket rods. When i asked him if it was a 496 rotating assembly he said know just stroker crank. So how does that compare??
From there he said he would warranty the build and throw brand new gm rectangular port heads on it,and a gm 502 cam with aftermarket oil pan. He is telling me 10.5:1 compression i told him multiple times i want a 500 plus hp motor... what do you pro's out there think.. I have a .6 lift bob m cam that i wanted him to install but he wants to stay from that and again put in the 502gm cam...... Please give me some feedback Thanks |
(Post 3775550)
From there he said he would warranty the build and throw brand new gm rectangular port heads on it,and a gm 502 cam with aftermarket oil pan. He is telling me 10.5:1 compression i told him multiple times i want a 500 plus hp motor... what do you pro's out there think.. I have a .6 lift bob m cam that i wanted him to install but he wants to stay from that and again put in the 502gm cam...... Please give me some feedback Thanks Not saying that it is definitely bad, but heard some bad things about that place in the past. |
I get a 1 year warranty and all parts are new, heads,cam, lifters etc
And how many hp was it?
Sorry just now saw the hp numbers.
| All times are GMT -5. The time now is 06:00 PM. |
