Sonic Bilge Redo Project Thread >
Old 10-24-2012 | 07:41 AM
  #31
Originally Posted by speedreeder
DONT TOUCH FREEZEPLUGS !!!!!!!!!!!!!! ANOTHER BIG CAN OF WORMS !!!!!!!!!! Good Luck Josh !!! Call me .....You know I got the good stuff for motors !! hahaha
Thanks Robbie.
FuelinAround is offline
Old 10-24-2012 | 07:48 AM
  #32
+1 on Superbrightleds.com . I have placed several orders with them and never a problem. Good prices and fast shipping.
I have tried cheaper "hong kong" leds off ebay and i was replacing them a week later.
Your engine bay looks good.
92nsx is offline
Old 10-24-2012 | 08:44 AM
  #33
F-2 Speedy's Avatar
I'm doin the same thing also, motors are out, whats the best stuff to spray on for cleaner, then wash off to prep for paint
F-2 Speedy is online now
Old 10-24-2012 | 12:15 PM
  #34
Randy Nielsen's Avatar
33outlaw. I used super clean from Oreillys & it worked REAL good. Randy
Randy Nielsen is offline
Old 10-24-2012 | 12:35 PM
  #35
Any good degreaser on the market will work for the intial wash, make sure to pay a lot of attention to the corners and areas close to the engines.
Want it to stick for good? Hit it with laq thinner next, a wipe down then rinse with water.
Follow with a 220 grit rub down, another rinse, and final with a wax/grease remover.
For paint I use rustoleum white with a valspar hardener added. Two coats.
4bus is offline
Old 10-24-2012 | 02:15 PM
  #36
Weed sprayer filled with purple power, followed by a heavy power wash, wipe down with towel, drill with a wire brush, wipe down again, spray with rust oleum high heat primer, spray with rustomeum high heat paint... Seems to be very well adhered.
Old 10-25-2012 | 12:53 PM
  #37
Royal Purple from Home Depot. Just ware gloves.
I also use rustoleum white (with a touch of almond to get the right color) with a valspar hardener added. Two coats.
f_inscreenname is offline
Old 12-11-2012 | 02:12 PM
  #38
Progress made....
*New 1 peice oil pan gasket installled
*remade oil cooler lines with AN hoses and titanium fittings
*Replaced all bolts on everything I removed with stainless steel bolts
Old 12-11-2012 | 02:13 PM
  #39
This week the billet pulleys and crossover kit will arrive. All I ahve left after that is a rebuilt carb and 1 motor is ready to go.
Old 12-11-2012 | 02:39 PM
  #40
Lookin good are you finished with the bilge? Those braided hoses are nice, looking forward to seeing some more pics. Randy
