-   -   Siearra Marine (https://www.offshoreonly.com/forums/do-yourself-boating-budget/286728-siearra-marine.html)
mysweetone 10-22-2012 08:01 AM
Siearra Marine
I need to replace my starter. I called my local West Marine for a starter and all they carry is Sierra Marine. Has anyone heard of this company? I was told to buy either a Mercruiser or Quicksilver product. Changing this thing is going to be a paine in the ass so when I do, I dont want to have to do it again for a long long time. Is this a reputable product? WestMarines cost is $215~.
F-2 Speedy 10-22-2012 08:20 AM
I thought Sierra was a division of Mercury
4bus 10-22-2012 09:55 AM
They make a lot of replacement parts that will go in the place of merc and quicksilver, however some have quality issues. The impellars for one are garbage, not sure on the starters.
I purchased some replacement tanks for the trim and tab pumps, they seemed fine and so far have lasted one season.
As an alternative this place does remans
http://www.ebay.com/itm/MERCRUISER-M...481c22&vxp=mtr
keith2500hd 10-22-2012 09:56 PM
i ilke and have had good luck with ARCO.
lawrengary 10-23-2012 01:22 AM
I thought Sierra was a division of Mercuryhttp://www.qrtd.info/12.jpg
Griff 10-23-2012 01:51 AM
No it is not part of Merc.
Quiicksilver is part of Mercruiser.
dereknkathy 10-23-2012 05:44 AM
orig big starter(s)? take em to a local rebuilder.
pqjack 10-23-2012 07:24 AM
+ 1
a rebuilt original beats a new taiwan
Knot 4 Me 10-23-2012 09:27 AM
Just replaced the impeller on my 496 MAG after 120 hours/2 seasons. The 2 prior to this one were Quicksilver. This latest one was a Sierra. Impeller looked like new. New one is again a Quicksilver. I saw no difference between the two brands.
speedjunky 123 10-23-2012 01:07 PM
I Arco seems to hold up longer for starters the rest of there stuff is good.
4bus 10-23-2012 01:55 PM
When I bought the sierra ones on amazon they were so inexpensive I bought 4. When I lost one on the lake I did not have my spares so I bought two new merc ones and installed one. I noticed it went in a lot harder, when I got home I compared the spare merc to the spare sierra....the rubber is at least 50 percent stronger.
1 MAIDEN AMERICA 10-23-2012 02:04 PM
The Sierra impellers are good for .25HP less parasitic drag and a 2oz weight saving. Maybe get you that extra .1MPH
Baja226sport 10-23-2012 02:19 PM
Sierra Marine is a divsion of Teleflex/Morse. No affiliation with mercury or any other engine manufacturer. However, in alot of cases sierra aftermarket parts are the exact same as what you would get from a dealer as not all engine manufacturers make all of their own components.
Sierra parts are oem quality and I would have no problem using anything they sell.
Griff 10-24-2012 01:51 AM
Some Sierra stuff is fine and some is hit and miss. Some of their products are probably manufactured by the same companies taht manufacture merc parts.
As far as OEM quality, that really does not mean a lot. I had "OEM quality" brakes put on my old 2500HD at a reputable shop. They lasted half as long as the original factory brakes.
mysweetone 10-24-2012 06:49 AM
thanks everyone for your help. Turns out a local dealer stocked Quicksilver starters so thats went in. It was smaller, lighrter and sealed! nice little starter!
HEDGEHOGER 10-24-2012 07:01 AM
whats this fancy new starter going in ???
Crude Intentions 10-24-2012 07:28 AM
Since we are on the starter issue. Who makes the best mini starter? So much smaller and lighter than the original. Much easier to finagle in the twins. I have offset bolt pattern.
dereknkathy 10-25-2012 06:39 AM
back to sierra parts for a sec. i fix canon copiers. i order a part, and frequently comes in a canon box with made in china on the label. everybody, even the OEM people use chinesium parts these days. as long as stuff can be made there that much cheaper than here, it will be...unfortunately, the savings goes into the CEO's pocket and the part costs us the same as if it was made in Dearborn Mich.
Baja226sport 10-25-2012 08:13 AM
Their products for the most part are indeed manufactured by the same companies as sold to you by your dealer.
And if your brakes only lasted half the time as what came from the factory then I would have to say they were not "oem quality".
I sell Sierra Marine and seldom have any issues or complaints.
BUP 10-26-2012 07:23 PM
Years ago Sierra starters use to come from Arco. IMO Arco starters are not that good. I have 1 or 2 bad right out of the box per year. MES starters are cheap and weak.
Today Sierra starters come painted black and are beefy. I use them now but they also are kind of expensive like Mercs PG260 starters as we use them also.
Merc and Sierra Bravo impellers & Black Plastic housings and that complete kit is the exact same made by the same people. The Sierra housing even has the Merc part # on it. Next in this app if you want a better Bravo impeller kit buy the Mallory Marine. I sell all 3 brands. U can see and feel that the Mallory Marine is a better impeller kit.
I use the MalloryMarine kit for my own stuff and sell which ever the consumer wants. Mallory Marine also makes better bellows & exhaust manifold gaskets FYI. Again I sell all 3 brands, OEM Merc, Sierra & Mallory Marine so have nothing to gain by saying this.
The brass Gen VII water pumps housings and impellers are made by Jabsco for Mercruiser. FYI
JMPH 10-27-2012 03:21 PM
Hey Guy's what about the bravo motor coupler, I am told same company makes them for both, does anyonw know if this true?
Twin O/B Sonic 10-28-2012 05:34 AM
Used to sell a ton of their stuff and have used a ton of it. All has been OEM quality w/zero issues. As a rep, only issues in field were self inflicted by poorly/non trained tech's.
bwd 10-28-2012 05:51 AM
Out of 15 yrs using Sierra I only had I bad cap. Only reason I stopped was my local distributor was bought by Brunswick.
Baja226sport 10-29-2012 10:19 AM
Originally Posted by Murphy93 (Post 3804754)
good luck with ARCO.http://www.bdoh.info/7.jpg
I have not had much luck myself with ARCO and they do not want to warranty either!
