Are BBC one peice oil pan gaskets better? >
Old 11-15-2012 | 07:52 PM
Originally Posted by keegan
FYI- TunerTech you will be tuning 33outlawSST's boat in the near future!!
thanks to you both
tunertech is offline
Old 11-16-2012 | 07:53 AM
Gasket installed last night. I ordered CP performance stainless bolt kit and the gasket is so thick the shorter corner bolts wouldn't seat so I used the original.
FuelinAround is offline
Old 11-16-2012 | 08:11 AM
I used one piece fel-pros on my last build and they worked great. Seems that everyone else has also had good luck with them.
endeavour32 is offline
Old 11-16-2012 | 11:16 AM
1 more question. The bead of silicone. I put it on the motor side of the gasket. Do most people put it there or on the oil pan gasket side?
Old 11-16-2012 | 01:57 PM
If you have a quality pan, good gasket silicone/steel reinforced, and clean mating surfaces you really don't need any sealer at all.. it's only a preference.. neither good or bad. If it helps you sleep at night DO IT.. just don't over do the sealant.
Old 11-16-2012 | 04:44 PM
Silicone not needed on flat surface, only a small dab at the 4 corners. Maybe PM a couple of the professional engine builders.
sonicss42 is offline
Old 11-21-2012 | 02:14 AM
I have a good friend that bought a boat a few years back. Took it out for the first time after he bought it and ended up with a hurt motor after that first day due to excessive sealer used on the pan gasket. The previous owner had just installed a new 572 in it and installed a marine pan when he installed the motor. The sealer flaked off on the inside, plugged the pick up and destroyed a bunch of parts! The motor lasted for about 10 hours. Using sealer on pan gaskets is common but just be aware of where and how much to use. I use it in the corners and sometimes on the timing chain cover section of the gasket.
mustangmark is offline
Old 11-28-2012 | 08:39 AM
I put a thin bead on the sides to help hold the gasket in place.
Old 11-29-2012 | 10:06 AM
Originally Posted by 33outlawsst
does someone have a part #
Originally Posted by tunertech
fel-pro 17986 oil pan gasket 7.4 & 8.2-liter gen v & vi
gen iv 454 fel-pro one piece blue molded rubber gasket old part# 1884R new part# 0S30061T
30ftpanther is offline
