Here is what I did in the spring of 2010.
1987, MIE/340 (7.4) 454 4 bolt main Big Block Dip it and hone the decks and cylinders cut .060 over Block was detailed with all casting debris removed Scat 9000 Crank 4.25, 496 stroker Scat 26385P - 6.385 in. Connecting Rods - Bushed -I Beam Forged 4340 steel Howards Cams 120255 - Max Torque Retrofit Hydraulic Roller Camshafts, Hydraulic Roller Tappet, Advertised Duration 288/294, Lift .585/.610, 112 L/S Howards Matching Valve Springs 98636 - 130# / 330# Cloyes Gear 9-203 - Cloyes Wear Plate, 031 in. Thick, Maxspeeding Hydraulic Retrofit Roller Lifters Probe 496 Dome Top +18.0cc - SRS Piston Set Clevite 77 Cam Bearings Federal-Mogal 4400 M20 Main Bearings King Engine Rod Bearings CR849HP Cloyes true double roller timing chain Mahle - Plasma Moly Coated piston rings Melling 10778C (Anti-Cavitation) oil pump Melling HV oil pump shaft. New Harmonic Balancer Rotating Assembly Fully Balanced Comp Cams High-Tech pushrods #7954 Completely refreshed Chevy Heads 14096188 / 454 Open / 118cc / 3angle valve APR head bolt sets ARP 1.90 rocker studs Norris S/S 1.7 roller rockers Seal Power Gasket set EDELBROCK BBC R2 AIRGAP INTAKE Pro Comp 2752 Fuel Pump Pro Comp Ignition Pro Comp distributor Super Stock coil 8mm Accel Hi performance wires New single wire alternator Mini (gear reduction and fully marine) starter Edelbrock 800 carburetor 12" aluminum, oval air cleaner (with K&N filter) Brass freeze plugs Stainless steel bolt set 4” Stainless steel "tall" risers 496 MerCruiser exhaust manifolds Sherwood motor mounted raw water pump |
Originally Posted by picklenjim
(Post 3867715)
If you can build a fresh 496 for 3K your a better man than me.
Your valvetrain alone roller cam, lifters, pushrods, roller rockers, springs, retainers, severe duty intake valves, extreme duty inconel exhaust valves is going to set you back over 2K EASY. Your still going to need the forged crank, manley rods, forged pistons, pair of heads, timing set, intake, carb, fuel pump, oil pan, valve covers, flame arrester, gaskets,machine shop work And why the oval port heads???? I didn't even know summit offered a oval port bbc head with their name on them. |
I jus built two for my 10meter.5grand a pop.time you dress it out easy five.....and that s using some used parts....oh yea,thats less exhaust.
Originally Posted by f_inscreenname
(Post 3868006)
fixx
done,,go boating...
http://www.competitionproducts.com/5...o/TSELB540095/ 540 short block under 4500.. http://www.competitionproducts.com/B...o/CPX540098SH/ |
Originally Posted by mrfixxall
(Post 3868382)
done,,go boating...
fixx
Originally Posted by MILD THUNDER
(Post 3868487)
4:19AM?? Dude don't you ever sleep :lolhit:
(Post 3868235)
I agree!!!
And why the oval port heads???? I didn't even know summit offered a oval port bbc head with their name on them. picked up a lot of my parts at a swap meet up here |
hey guys im not trying to start anything **** on here im just looking for advice and letting people know about how my build is going is all
just about the single cheapest part you are using is the block. find another one. one that spent it's life being cooled by anti-freeze instead of salt water.
