Cam suggestions
Im building from scratch a Gen6 454 Mag. 10:1 JE pistons, Scat crank and rods, +.030", 088 stock heads, 1.7:1 crane gold pro roller rockers, EMI thunder, factory MAG EFI intake.
Im now looking for suggestions on cam shafts and lifters. Here's what I want:
Dont want to buy springs if I dont have to. What brand and model of each would you recommend and why ? |
I recommend talking to Bob Madera, he is the master when it comes to cams.
I'm in the middle of my build which is similar but 502 based. I think your 10:1 is going to be to high for the 088's. Only going off what I've researched and been told by bob. I'm working with him as well on cam and valve train for my 509.
fixx
isky 696265/275 advance it 2* will put you at 1800-5800..real strong midrance cam and is good with computors..also check with mark boo's if he is reprogramming the ecu..
Originally Posted by oregondunes
(Post 3877621)
Dont want to buy springs if I dont have to. What brand and model of each would you recommend and why ? P.S. Hopefully the weather co-operates for you to make it to Vic from the San Jauns. |
Originally Posted by thisislivin
(Post 3880715)
i recommend talking to bob madera, he is the master when it comes to cams.
I picked up a cam from an OSO member here. It's a EFI HP500 cam (.600" 232/242). The stock 502 cam is .5814" (difference of .0186"). Will the stock valve springs handle this increase or should I be looking for something stiffer (maybe these ??? http://www.cpperformance.com/p-11722...e-springs.aspx)
On my road race cars of days gone by, we would machine down the valve spring seats and install torrington bearings. Is this still something people do ? It was also a way to run stiffer springs with less initial pressure = less wear on valve train. |
You would be better off just to get a new set of the correct springs for that cam at this point instead of reusing an old set.
Originally Posted by picklenjim
(Post 3907988)
Im not against it, but the $150 could be spent else where |
i recommend talking to bob madera, he is the master when it comes to cams. |
| All times are GMT -5. The time now is 10:52 AM. |
