Stellings header leak
I have the "Steroid" header. Motor is out ...Took one to get a small crack on the outside fixed and when put on the hose more leaks showed up internally.
One near the #1 cylinder that was repaired, the other at the collector and one that could not be seen. The welder could not 100% fix the collector leak. He says the wall is too thin and theres some pitting on the rest of the header internally. These are 2002 , is that all a $7500 set lasts? 11 years and their done? Not a good day for me, I checked all plugs and exhaust ports and there no indication of reversion. Figure hes testing it on 45psi residential water pressure.. all these will see is 17psi.. Thought?! I can`t pull off a new set right now...hoping the leak is smaller at less psi and just blows out the exhaust??? |
Sorry to hear!!!!! I know how ya feel. Reduce the pressure at the hose to 25 to 30 and see what happens.
fixx
here is the sad part,,wtelling is out of the header biz so you phucked on trying to replace one set in the future..after about hearing about the one i would pull all of them and check them,,better then replacing the blocks when water gets into your cylinders and hydraulisc's the block wide open..put a self drain kit on the headers so they drain when your sitting..
Originally Posted by FIXX
(Post 3893888)
fixx
Originally Posted by GAZ
(Post 3893901)
What is a self drain header kit? Will you explain please. I might be interested in them. I drain my complete block and headers every time I use my boat.
I feel your pain$$.thats a big ticket item.i am like u.that kind of coin they should last longer.
Well I brought the header home tested it and I don`t see the big deal. I get nothing when I hook it up to the hose full blast and when i restrict one end I get a little seapage at the collector.
When is the header going to have 45psi in it and nowhere for the water to go as he was testing it?? Never Its a good day:thankyouthankyou: |
fixx
Originally Posted by ICDEDPPL
(Post 3894568)
You can call Stellings and they have a contact person that can replace the collector and repair any leaks. The guy was pretty cheap. I sent mine back to him and he replaced the entire collector for $350 and it came back looking like new.
Originally Posted by cdail28590
(Post 3894963)
I'll look for it tonight. I think I have the guys # filed away.
Just wondering if jbweld will work, if you tried everything else an can't get it done??:party-smiley-004:
sorry hear about he leak, i was thinking the same thing, you pay stuid money for these ss headers and they only last 8 to 12 years, i guess that where the word B.O.A.T. brake out another thousand, but in my case latey it seems like it's been ten thousand:lolhit: |
(Post 3895146)
Well how awesome is that !! Do you have any contact info??
he replaced the headers with stainless marine manifolds.
I've found a few people locally who can do it. Put the word out and start asking around. Welding shops, race car chassis fabricators.
(Post 3894963)
Need even that info phone or email |
Please start new thread. Ask the question you need answer to. Reviving 4 year old thread wastes everybody's time.
| All times are GMT -5. The time now is 11:42 PM. |
