NAPA Syn 15W-50  3.49/quart >
Old 04-12-2013 | 03:34 PM
Default This is a good deal
http://www.farmandfleet.com/products...l#.UWhvlqKsiSo
ICDEDPPL is offline
Old 04-12-2013 | 04:21 PM
Their price on VR1 is good too!
http://www.farmandfleet.com/products...l#.UWh6izYo51s
MILD THUNDER is offline
Old 04-12-2013 | 04:40 PM
Why yes it is..
also its time to do oil change on the 7.3l
http://www.farmandfleet.com/products...l#.UWh_AaKsiSo
ICDEDPPL is offline
Old 04-12-2013 | 04:50 PM
Originally Posted by ICDEDPPL
Why yes it is..
Big spender! I have always used Rotella, or Delvac, in my Mack semi. Its a 12.0L turbo diesel with 32lbs of boost under full load. It has 31,000 hours on it, over 800k miles. oil pressure is still great, and no engine noises or excessive oil consumption. You can find it for around 11 bucks a gallon a wally world or sams club. It does hold almost 10 gallons, so I have to be frugal lol
Old 04-12-2013 | 05:05 PM
longest smilie effect ever lol
ICDEDPPL is offline
Old 04-12-2013 | 06:31 PM
sommerfliesby's Avatar
Not to mention, you can use leftover Rotella in your sled!
sommerfliesby is offline
Old 04-12-2013 | 06:56 PM
i like the rotella oil for my diesel also and il bet it would be great for most marine engines.
mike tkach is offline
Old 04-12-2013 | 10:38 PM
Yes!!! I ran diesel oil in my sled and you ran diesel fuel in yours!
Old 04-12-2013 | 10:42 PM
A fellow Hammond boater has run Rotella 15w40 in his boat engines for years. He had 700+ hours on his 502 mags when pulled them to upgrade power. Still running perfect when pulled
Old 04-13-2013 | 12:06 AM
Default fixx
hell you may as well do a trans service as well,i use their mystic brand all the time and it works great..
http://www.farmandfleet.com/products...l#.UWjnXqIsnTo
also their mystid gear lube is real slimy and i have used it in the past,,it clings to the gears like grease and cushions the gears when they ride against each other..
BTW dan,,dont recycle your oil in your fuel tank anymore.(i saw a video somewhere)..in the last year i have 2 friends that use to do that and now they both are proud owners of a new 6.5 and the other a new 7.3 diesel engines..their are tiny particles of metal in used oil and unless you have a rack of filters lined up for your fuel to go through it will eat at your cylinders..
FIXX is offline
