-   -   How to test my cmi header (https://www.offshoreonly.com/forums/do-yourself-boating-budget/294411-how-test-my-cmi-header.html)
caseyh 04-10-2013 09:44 PM
What is the proper way to test headers for leaks. Pics would be great.
POWERPLAY J 04-11-2013 06:33 AM
Plug one end and hook up a garden hose to the other. Turn it on full blast and wait a few minutes.
thirdchildhood 04-11-2013 07:08 AM
This is how I did mine:
http://i763.photobucket.com/albums/x...s241Medium.jpg
twestedsticks 02-22-2016 04:40 PM
How much psi thank you
thirdchildhood 02-22-2016 05:23 PM
I used 40 psi. Let 'em sit awhile with the water jacket pressurized and watch for any bubbles.
twestedsticks 02-22-2016 07:27 PM
Thank you very much.
seafordguy 02-22-2016 08:02 PM
You should check a post I did in GD asking the same question. Several ways to skin it. I ended up getting an air gauge as recommended by one of the members in that post and going that route.... Worked great and I didn't have to take the headers off..
twestedsticks 02-22-2016 10:23 PM
What was your pressure at,,thanks.
seafordguy 02-23-2016 06:05 AM
I tested them at 30psi.
I Let them sit overnight.
i took the hose end off the thermostat housing, used he right combination of fittings and connected it there. Then I stole one of my caps off my other header, capped off the water hose on top of the header, filled it to 30 psi and let it sit.
I will also say, I drained the water before I did that so that if there was a leak it didn't force water into the heads...
twestedsticks 02-23-2016 01:15 PM
thank you.
