-   -   Oil pan fitting 7.4 (https://www.offshoreonly.com/forums/do-yourself-boating-budget/295336-oil-pan-fitting-7-4-a.html)
Smithelectric 04-27-2013 01:29 PM
Oil pan fitting 7.4
I have a 88 7.4 putting back together after a couple years and on the oil pan there is a drain plug and the otherside has a brass fitting for like a oil cooler line but can't figure what goes there . Thank you
fireboatpilot 04-27-2013 06:58 PM
Might have been for a line to an oil change pump or drain hose to the garboard plug? What size line/fitting we talking about?
f_inscreenname 04-28-2013 09:44 PM
Oil drain
Griff 04-29-2013 01:37 AM
The second threaded hole can be used for an oil temp sender or just plugged with a brass pipe plug.
Smithelectric 04-30-2013 07:51 PM
its for the dip stick
