Fresh 355 with a cough when the stick is moved fast. >
Old 06-03-2013, 07:52 PM
Default Fresh 355 with a cough when the stick is moved fast.
I just built a 355. It has flat top pistons, vortec heads, 262/268 xtreme marine flat cam, vortec heads, air gap manifold, and an Edelbrock 1409 carb. 28 degrees of timing all in. Runs awesome. My only issue is a cough through the carb if I gun it as if I was pulling a skiier. It will also do it at cruise if I lay into it fast. If I ease the throttle its fine. What could it be?
79formula is offline
Old 06-04-2013, 08:21 AM
Knot 4 Me's Avatar
Timing.
Knot 4 Me is offline
Old 06-04-2013, 09:45 AM
It also very well be the accel squirter, I would make there that is adjusted right and your getting enough fuel.
Baldie is offline
Old 06-04-2013, 10:06 AM
there are 3 holes on the accelerator pump arm, i believe they come from the factory in the middle hole, move it to the hole closest to the shaft for more pump shot, I think I had to do this also (350 vortec, lt4 hot cam). Also you should be able to run 30 degrees timing.
Mr Maine is offline
Old 06-04-2013, 11:21 AM
Originally Posted by Knot 4 Me
Timing.
X2. Bump that timing up some more.
matthewr is offline
Old 06-04-2013, 12:12 PM
I moved the accel pump to the closer hole and bumped the timing up to 30. I will let you know tomorrow.
Old 06-13-2013, 10:50 AM
Sounds like accelerator pump issues to me.
MILD THUNDER is offline
Old 06-13-2013, 12:35 PM
I had a 355 built once at it had the same problem, especially try to get on plane. I had a Holley and Holley told me with the crap gas in my area bump up the secondarys 1-2 sizes. Went 1 size and fixed the problem.
WHIPLASH is offline
Old 06-14-2013, 12:35 AM
I'd lean more towards this being a fuel issue. I've seen 28 degree timed motors do just fine, granted it may not be optimum, but no coughing etc.
Trash is offline
Old 06-14-2013, 05:08 AM
vintage chromoly's Avatar
Yep. 100% fuel issue. I agree that timing should be around 32-34 but that will not bog it down on quick acceleration.
Think of a boat as a 5000# Lincoln trying to go up a 45 degree incline in 3rd gear from a dead stop. You are going to need some fuel with that kind of load.
Buy a carter/edelbrock tuning kit and fatten up the fuel curve right "off idle.
vintage chromoly is offline
