carb to EFI...500/525 setup or holley/fast/ect?
Basically when i rebuild my HP500 carb motors this winter i'm thinking i want efi. They're stock with 525efi cams but am thinking about raising the compression or even stroking them which isn't the issue. The question is how involved would it be to retrofit my motors with 525 or 500 efi hardware? What all would i need? Or do i go with a carb replacement kit from Holley or fast? I really want the stock appearing blue paint but at a certain point it might not be worth the headaches. Theres several twins sets: intakes, intake manifolds, rails, harnesses and ecu's in the swap shop for around a grand or a little better depending on the misc sensors and parts to make them work. i know i'd have to change my fuel system either way. I know these motors are known for being difficult to diagnose and work on but what about setting them up from scratch?
Thanks, Riley |
Originally Posted by Rbesola
(Post 3943222)
Thanks, Riley I run Holley on my car and love it. |
This is just an idea but could it be possible to run Holleys new Terminator EFI. Setup? It's not out yet to the best of my knowledge and is meant for the automotive world but may work for us as I have thought about trying this.
I did this this past winter with my 1995 Top Gun, it had 525SC's and I wanted FI. I went with a Whipple kit which included the fuel system, computer, harness and all sensors, of course in addition to the blowers.
Basically, and others can chime in on where I'm wrong or what I'm missing, you're going to need the fuel system, the computers, the harness (for the engine) which will plug into the main cannon plug on the boat harness, and then whatever sensors are required. It's certainly doable and fairly easy, as always it just comes down to money. Since you have time you can most likely piece it together over the months and then get out of it pretty reasonably I would think. For me the FI was the only way to go and I'm very happy I choose this route. Good luck whatever way you decide to go! |
I have converted from carb to EFI twice.
The first time I used stock MPI stuff and used the MEFI Burn program to dial it in. It worked fine, but was a lot of work. It was all purchased used, which created headaches diagnosing issues and getting them handled. Second time around I used the Holley HP. What a difference! Self-tunes, and everything was new, making the hassle factor all but disappear. It also appears close to a stock carbed engine when done. I've always hated the look of the MPI system. Do your self a favor and go with the Holley. If you do I would suggest purchasing it from Alex Haxby. He can solve most any tuning issues over the phone in just a few minutes, and his prices are competitive with any of the big dealers out there. |
Many things im thinking about. Holley efi on what i have, dual efi quads on 871s or whipple setups? Not looking for crazy power numbers and really want realtime self tuning software for piece of mind and economy. Anyone ever put the dual quad on a blower?
For what its worth, the real-time tuning isn't all that its cracked up to be - however self compensating is what is nice. It took me about 20 minutes on the water to run mine and get it completely tuned after I got it started and running in my driveway. I short blast up and down the river, and my AFR is rock steady at 12.8:1 at WOT, and around 13.3:1 in cruise.
(Post 3943222)
Thanks, Riley |
Originally Posted by Baldie
(Post 3959711)
Rbesola I'm looking for the same thing. I'm just running NA 572's but I'm tired of my carbs.
Originally Posted by boatfreak
(Post 3962366)
2 Attachment(s)
I'm real happy with the Holley HP setup and their software is a snap. I did this over the winter. Just make sure you mount the O2's where they are not going to see any water. Just got back from LOTO this week with 20 hiccup free hours.
http://www.offshoreonly.com/forums/c...r-project.html |
Originally Posted by rvander68
(Post 3965148)
Keep in mind, the stock 500efi intake is only good to a little over 600hp before it won't flow enough.
(Post 3965861)
Very cool! Love the stacks. On a side note... Talked to Simpson motorsports for a good half hour today and he didn't sound all too positive on the holley stuff on boats. Also said the tuning is not just a matter of running it? He did say if i go that route to go with a multi port setup for a more even fuel distribution. Basically just not the new "game changing" terminator. So far im not sure what to believe
I have a pair of complete Cutler systems. One is perfect and one has a bad ECM. They were on my Dad's boat and he went back to carbs, as no one around here is much of an EFI expert. I am sure there is a way to have an ECM made. Make offer!
| All times are GMT -5. The time now is 03:55 PM. |
