-   -   twin 350 replacement suggestions (https://www.offshoreonly.com/forums/do-yourself-boating-budget/299416-twin-350-replacement-suggestions.html)
chekmark 07-08-2013 11:30 AM
I one of my engines in my 1984 chris craft stinger 26 this weekend. Thinking of replacing both engines with marine engines from usengineinc.com. They offer a 350/300 hp long block and offer 7 year warranty. I don't have unlimited funds but don't see just replacing one engine as a good idea since they are both original engines. Anyone have any experience with this company? Any help would be appreciated. Want to this rebuild right the first time!
Crude Intentions 07-08-2013 11:46 AM
I'd be interested in what type of pistons crank etc. they stainless valves which is good but no mention of compression or piston type.
phragle 07-08-2013 01:03 PM
this is from a quick google on them
I purchased a rebuilt engine for my Boat in April of 2011 from US Engines Inc. in Kent, WA. Within a few hours of use the engine dumped large quantities of oil into the bottom of my boat. I took it back to US Engines who provided a 7 year warranty with the engine. They claimed to find the problem and fixed it after a couple of weeks in their shop. I used the boat again and same problems occurred within a few hours of using the boat. I brought it back and they claimed to find and fix the problem again. I used the boat and again the same thing, massive oil leaks with minutes this time around. I brought it back a total of 4 times in 2011 and my boating season was completely ruined. During all of these repairs they blamed the leaks on many different problems including: holes under the timing cover and fuel mixing with the oil. They even claimed to have put a different engine in my boat but the serial number remained the same on the block.
Also in 2011 while the boat was in their shop they managed to break off the key in the ignition, break off my throttle, leave wires exposed to melt and overheat on the engine which caused the electrical system to shut down. During
different repairs they did not even replace parts such as my exhaust shutters and screws that hold the engine compartment in place. Worst mechanics I have ever dealt with.
In April of 2012 I had the engine DE-winterized and I took the boat out the 1st weekend in May. The engine dumped the
oil again within 30 minutes of use. I complained to Charlie Silvers at US Engines and I told him I will not bring my boat back due to the unprofessional work done in 2011. He referred me to Lake Washington Boat Center in Auburn, WA.
I agreed to let them try to fix the oil leak issue. They had the boat for 2 days and claim to find the problem (hold under the timing cover) and that it was fixed. We tried the boat again and it dumped the oil within 5 minutes of use on the water. I did extensive online research and found that Lake Washington Boat Center owns US Engines and Mike Crossan is the CEO. They have continually denied that Lake Washington Boat Center is affiliated with US Engines.
During online research I discovered Lake Washington Boat Center/US Engines has changed their business license and legal name 9 times. They have operated under the names: Lake Washington Boat Center, US Engine and Import Engines inc., US Motors inc., Lake Washington Boat inc., Lake Washington Boats, US Engines Corp., US Engines inc., US Engine, and US Marine and Domestic Engines Inc. I also found extensive negative online reviews. Most of these complaints and stories are similar to mine. Faulty engines and oil leak problems. Charlie from US Engines has commented back to many of these complaints with the same response: "Not our Fault" and blamed the problem on the consumer.
I agree with many of the statements in consumer online complaints: This business is fraudulent, unethical and scam artists. One complaint even stated "The owner should be in jail."
The Better Business Bureau has 33 complaint cases against US Engines in the past 3 years for problems with product/Service and Guarantee/Warranty Issues. They claim to have an A+ BBB Rating but they do not have accreditation with the BBB. I also found 30 Superior Court Cases against US Engine since 2000 and 6 District Cases. I currently do not know the nature of these lawsuits and the outcomes but I am not sure how any business can
survive this much litigation against them.
They will not refund my money and they have clearly demonstrated they cannot or will not repair my faulty engine. They blame me the consumer for the oil leaking issues and they will not stand behind their warranty. I wish I had done my research before doingbusiness with them.
This report was posted on Ripoff Report on 06/09/2012 04:51 PM and is a permanent record located here: http://www.ripoffreport.com/r/US-Eng...anty-In-895277. The posting time indicated is Arizona local time. Arizona does not observe daylight savings so the post time may be Mountain or Pacific depending on the time of year.
Ripoff Report has an exclusive license to this report. It may not be copied without the written permission of Ripoff Report.
Then there is this,
http://www.bbb.org/western-washingto...kent-wa-511160
Try googling us engines complaints
chekmark 07-08-2013 01:11 PM
So they don't look good! thanks for that info. any suggestions where to turn?
phragle 07-08-2013 01:24 PM
I just saved you several thousand dollars. That will be 2 cheeseburgers and a bud light. Thank you and have a nice day :)
masi242 07-08-2013 08:30 PM
I know it`s not close to you but we have used this place before with good luck. Look up 1800runsnew they may have what your looking for.
mark
chekmark 07-09-2013 04:55 AM
thanks. will check them out.
Sonic30ss 07-09-2013 05:06 AM
+1 on 1800runsnew
Bought the complete (carb to oil pan)320 horse engines
Just changed the oil last night at 285 hrs.
Still run perfect, and I'm not what you would call easy on them ��
chekmark 07-09-2013 12:22 PM
anyone know anything about rmp marine engines
FIXX 07-09-2013 05:04 PM
i always use eagle engines,,,this one when replacing.come with vortec intake flywheel all the tims and a new harmonic ballancer..call and find out a price,,cant tell you what i pay for it..http://www.eagleenginesales.com/marine-new/view/2541-SC
BTW its a 330 hp engine and runs real good!..
