496 Stroker Build Help which Cam? >
Old 08-05-2013 | 12:18 PM
Default 496 Stroker Build Help which Cam?
I am buikding a set of 496 Strokers, but dont know what is the best Roller Cam for this setup.
1- Gen 6 Blocks 0.60 Over, Roller Block
2- 4340 4,250 Crank
3- H beam Rods 6.385
4- Icon Pistons IC9951
5- 088 Heads
6- Holley Carburater
Whats the best Roller Cam for this Combo?
Any help will be greatly appreciated.
Frank
automobili_v12 is offline
Old 08-05-2013 | 08:29 PM
Thats a very open ended question.
Lots of other things come to mind:
What exhaust? what your goals are for the boat? Compression ratio?
Building a good motor takes a lot of planning
vince1645 is offline
Old 08-05-2013 | 09:46 PM
do yourself a favor and call bob at matine kinetics 585-654-8583..he is the man..
FIXX is offline
Old 08-06-2013 | 04:07 PM
Craney's Avatar
Listen to what Fixx said call Bob. I'm also building 496s and I called Bob and glad I did.
Craney is offline
Old 08-07-2013 | 09:53 PM
YES, no need to re-invent the wheel! Bob knows what works for YOUR specific combination of parts! TBF
tpabayflyer is offline
Old 08-09-2013 | 07:56 AM
You did not post what exhaust you are running. That would be the most important part.
I have built several 496 strokers with Bob cams. They run great!
1BIGJIM is offline
Old 08-14-2013 | 02:02 PM
BajaIceBreaker's Avatar
This thread has only been dead a few days, so forgive me if i hijack it a little early...
Let's assume these specs...
9.5 compression, EMI Revolution Marine exhaust (comes out under the water), heavy boat, dual plane intake. Current cam is Crane Roller Retrofit --> .553/.556 lift, duration @.050 214/222 --> What would you guess on Horse Power? Do you think this cam is a good match, or could I stand to go bigger?
BajaIceBreaker is offline
