-   -   Fountain FEVER 32 ADVICE (https://www.offshoreonly.com/forums/do-yourself-boating-budget/302328-fountain-fever-32-advice.html)
louisfever 09-01-2013 07:28 AM
Im interested in buying a 32 fountain fever with twin 502 mpi engines .....
Would like for FOUNTAIN 32 fever owners to check in and say what the gota say about this boat
Performance ???
Pros and cons ???
How to get the stern higher then the water line ??????????????????
SPEEDFREEK 09-01-2013 08:25 AM
I had a 98 with 502 Mag MPI's, Bravo 1's, Hydromotive 28 pitch Quad 4's for 10 years. It was a fantastic boat for me. Here in the Chesapeake bay where waves can get ugly 3-4', once I learned how to drive the boat and use the K planes it did very well. It jumped on plane well without having to hammer the throttles, top speed was 78 on GPS. It was very tight in the bilge to perform any maintenance but, the engines were great, very dependable but I spent most of the time cruising at about 3200 RPM. The stern sitting so low is the nature of the beast, not anything you can do about that.
boatnt 09-01-2013 09:06 AM
Yep,,I have a 32 with 502s,,love the boat,,,
BLUEMAGIC 09-01-2013 11:09 AM
yep mine sits right at rub rail with tall decks and stellingsalways have water i n it no big deal allways get looks fun boat thinking about nerf footballs to but in vent holes while sitting out in the like
Fenderjack 09-01-2013 12:23 PM
Got a 32 non step stock 340 hp carbed 454's just changed to 27 mirage props cruises at 46-48 mph depending on fuel at 3000 3100 rpm great on fuel.Tops out at 5100 and 72.3 mph + - Great ride luv it.Very touchy to tabs JOHN SR
GeeterB 09-02-2013 06:49 AM
I have a crazy question about this boat...has anyone ever put donovan aluminum blocks and other weight saving systems to raise the stern?
moderatedUser23082018 09-02-2013 08:24 AM
Had one for a year,, great boat but no room to work on motors and most of them leak water at the Rub Rail. Overall best bang for your buck.
louisfever 09-03-2013 09:36 AM
Thanks guys for replying .... They run pretty fast with stock power .... Ive been doing alot of research about this boat cause im from MALTA and there isint 1 here ... I learned from here about the rubrail leaking but thats an easy fix as im a jack of all trades ......
Most of the time it will be driven at criusen speeds but at times I like to hammer the throttles cause im a spped freak and we do alot of over nighting at Comino over the weekends so it seems to be a wise idea to block the rear vent holes while the boat is moored !!!!!!!!!!!!!!!!
Thanks guys and keep posting :cool-smiley-027 and stay safe !!!!!!!
Gunn 68 11-18-2016 02:18 PM
can any one out there i am looking at a 2003 32 fountain twin 350 mags how fast will it go???
getrdunn 11-18-2016 02:49 PM
I'd take a crack at it. Prolly like 63-64. Would be awesome for a couple revved up 383 builds.
Gunn 68 11-18-2016 02:57 PM
i figured about that speed the guy at the marina said 70??? that is why i asked thanks getrdunn i have a 24zt checkmate that has a 383 procharger 573hp hydralic sterring and k plates gps 83mph run out of hull and kinda scary looking to up grade
Wildman_grafix 11-18-2016 09:21 PM
There is at lease one person on here with the small blocks, I thin they are right at 70, no more.
ezstriper 11-19-2016 07:45 AM
the main thing you need to be concerned with is the transom, forward bulkhead and possibly stringers rotted out, these are known to have these issues, so ck closely
Gunn 68 11-21-2016 12:55 PM
thanks
DiamondPerformance 11-21-2016 01:02 PM
I would look for a 35 instead of a 32, a lot better balanced boat. Same power, the 35 is faster.
