93 Powerquest 270 laser twin 350 mags motor build help.
1 Attachment(s)
I have a 93 Powerquest laser 270 with twin 350 mag carb motors in the boat right now.
475 hrs on them and both run great. I want to hit 70 with this boat and she does about 65 right now. Alpha drives. Both replaces with only about 100 hrs on them I want to build these motos to put out 350 hp instead of the 270 they have. What is the best and easiest way to hit that route I don't want to replace out drive either. Will the alphas hold 350 hp with this boat and being twins. I would think so. I'm going to put drive showes on them first. Then what should I do next. |
Think cam and heads. Sprink has some 400hp + 355s. Not difficult to achieve. Think vortec heads and intake. Cam up a little and larger carb.
Yup vortec heads, cam swap, and intake would easily put you at 350hp. I went from 53-54 mph to 66.
