What upgraded Oil Pan for 575sci?
http://www.jegs.com/i/JEGS+Performan...50236/10002/-1
I think I might go with this one, I cannot fit a real deep pan. Dont have mine available to measure but I think my stocker is 8qt...this one is 11+ filter.
As far as oil temp, I would venture to say mine would never have a problem. I have AFR aluminum heads, Whipple cooler, and rune a 120* stat.
I think I might go with this one, I cannot fit a real deep pan. Dont have mine here to measure but I think my stocker is 8qt...this one is 11+ filter.
Thanks Mike for the info, I am no expert on this stuff but I do ask a lot of questions from people like Dustin at whipple and Bob Mandrell, at Marine K. and when I got my motors done, I asked what parts I need to get for the power range I wanted to be in and also to help prolong the life of the motors. I know you know what your taking about when it comes to this stuff I read tons of your posts, and I value your knowledge and expertise....thanks Joe
not sure what boat you have but you might have problems with that on a mercruiser package,the sea pump wont clear the pan.i think you will need a pan like tcwcar has,a marine specific pan that is made to clear things like the sea pump,and the motor mounting plate with hi perf mounting system.
The boat is a Profile cat and I have the offshore style performance mount. The problem is that the pan has to fit between the center pod...I dont think a pan like twcars will. Also with the stock pan it is pretty tight between the deep end of the pan and the bottom of the pod.
