What is prompting the builds? Did you lose one or both? I'm holding off on props as I mentioned earlier. Bob put a 4 BBL carb he had laying around and made another 15 HP, so we know the throttle body is choking the engine some. BBlades thought I should wait until I do that, then probably jump up to a 25p and lab that. So far I've got a max of 72. One of the engines is giving me an alarm at WOT so I've not been doing any hard running besides long cruises until I scan it. Which she's done great on, I've kept the stock oil pan because it seems to be working great. Ran 3500-4k RPM from Clear Lake TX to Galveston, TX and my oil temps were perfect. If I wanted to lab what I have, they think there is a few MPH there. But, really...I'm just loving the acceleration and having a great running boat again so it's not high on my list right now. I forget who programmed it, I could dig it up when you're getting closer.
Originally Posted by Reds9050
(Post 4201956)
Also, why the small/stock oil pan and who programmed your ECM? Have you had any issues since the builds?
Originally Posted by Captain YARRR
(Post 4202718)
If I were in your position I'd sell your stock engines and buy one of these bad ass big block setups I see for sale. You'd spend similar money. If not that, I'd sell them and do an LSx build.
I love my engines but I only did the build because I had to rebuild them either way and this build wasn't a ton more. |
(Post 4202904)
Where are you at? If you do dry headers you will hit 450 easily with my build. We held back a lot on the cam and if you do throttle bodies you might even do better.
I would really read over the Skater LSx build if I were you. That thing is nuts. |
Hey guys, I just dyno'd a small block for a 68 Camaro. It was a 427, dart block with dart 200 cc heads, 10:1 compression and a pretty big hydraulic roller cam, single 4 bbl carb.. It made over 600 HP at 6200 RPM. I was really impressed with the numbers. You could build a similar marine version that would easily make well over 500 HP in full trim.
Dart/AFR406
1 Attachment(s)
The attached build sheet is for a marine Dart SHP 406 w/ AFR 195 cc heads with a mild hydraulic roller. This went into a Magnum Starfire ~ 5 seasons ago. A very tractable, durable piece.
Bob |
(Post 4203403)
What was the cost of something like that, injected or Carbureated and if injected, what kind of delivery system? Whichever route I go, Id want the combo tuned while in the boat
| All times are GMT -5. The time now is 08:33 PM. |
