-   -   Crankcase ventilation (https://www.offshoreonly.com/forums/do-yourself-boating-budget/306065-crankcase-ventilation.html)
jamie 10017 12-05-2013 07:10 PM
I wanted to see what type of crankcase ventilation you guys are using I know Mercruiser just had vent tubes running up to the flame arrester, that just seems a little outdated and on my engines witch had a little blow-by it made a mess of the F/A and down the sides of the carbs after a long run. I'm just looking for some ideas of how you run yours ? Do you use puke tanks or PCV valve, or just breathers in the covers. I am not sure even if there is any USCG laws on how they want it to be vented. Thanks Jamie :cartman:
f_inscreenname 12-05-2013 10:13 PM
I use PCV and a breather cap.
sdrockslangers 12-05-2013 11:05 PM
Puke tanks .... Clean as whistle now. Had a mess every time bbc with 177s. Soon as these were installed no more problems
abones 12-05-2013 11:14 PM
Dual inlet puke tank on each motor, hose from each valve cover to the tank, works great spotless motors.
ezstriper 12-07-2013 08:22 AM
on most of all my boat engines I have switched to PCV valves in one valve cover, vented to flame arrester out of other...merc started using PCV's on the 500hp and 525SC, pretty much on all now
ICDEDPPL 12-07-2013 08:41 AM
The K&N type filters make a mess on mine, sometimes they pop right out and make even a bigger mess before I realize it... I`m switching to these:
http://teaguecustommarine.com/em0011...-breather.html
turbo2256b 12-07-2013 09:05 AM
Comverted most all the boats I have owned to PCV valve set ups. If possible hook the PCV valve to pull from the lifter valley at the front or rear of the engine. Install breathers in the opposit end from were the PCV was installed. Also plumb the breathers into the air cleaner as most cars were from the factory.
MILD THUNDER 12-07-2013 11:46 AM
I personally don't like pumping oil residue back down my carbs, or intakes. My boat doesn't have to pass an emission inspection. Puke Tanks are a really good way to go imo.
FIXX 12-07-2013 02:32 PM
+++ puke tanks,, or a vaccume pump plumbed to a puke tank for the bigger blower and ci engines..
abmotorman 12-07-2013 10:45 PM
IMO - if you have blow by, you need a puke tank. No sense gumming up the valve steams and tops of the pistons.
For a naturally aspirated marine application that isn't experiencing blow by I like the PVC setup to help in condensation / oil contaminates removal. Especially for those running cooler than stock thermostats that barely gets the oil to operating temperature. Also, doesn't hurt to have a LITTLE film for winter layup. Some may say it aids in upper lubrication similar to lead did back in the day while engines are loaded.
Blowers- puke tanks are a must. Vacuum pump added would be ideal.
ThisIsLivin 12-12-2013 12:24 PM
That's what I have on mine. I usually run my boat pretty hard and only see a minute amount of vapor from the breather. I'm running a pretty big cam and in gear I only pull 4" of vacuum at idle so I don't want to try a PCV. My motor only has about 80 hours on it so it's still pretty tight. Has anyone tried extractors in a marine application? I know it's only worth a couple of hp on the top end but would certainly keep the bilge clean.
troper 12-13-2013 04:40 PM
Anybody got photos of their puke tanks installed?
