they make a adapter for those, So you do not have fuel up to the dash. Just like inside cars. It has fuel up to the isolator, then has antifreeze up to the dash where the gauge is.
http://www.summitracing.com/parts/at...FatcMgodFDsAag |
Originally Posted by kickin32
(Post 4066376)
Originally Posted by jbraun2828
(Post 4066339)
There's quite a few wires back behind the dash don't you think? I guess it depends on your motor as far as fuel pressure gauges. If your running big ci blown motors it more important to monitor than a stock 454.
auto meter makes an isolater so you do not have fuel all the way up to the dash area plus its a a lot cleaner look i just installed a manual gauge off of my fuel rail you have to have the hatch up to see it but i thought it was a lot easier
Originally Posted by Black Baja
(Post 4065905)
Has anyone ever attempted to put a sail on a performance boat? I guess that's what I'm gonna have to do so I can get around.
I run mechanical gauges on my separator housings in the bilge. Mainly for tuning and trouble shooting though. Oh, also twin small block setup, so no high dollar stuff! |
If you stick with a low pressure carb set up I wouldn't see a problem so long as everything is properly attached, however if you get your fuel injection set up going & have high pressure fuel going up to the dash I would want proper line & fittings as recommended by gauge manufacturer. Randy
electrical is the way to go.
| All times are GMT -5. The time now is 07:04 PM. |
