-   -   LED Lighting Suppliers (https://www.offshoreonly.com/forums/do-yourself-boating-budget/308500-led-lighting-suppliers.html)
stimleck 02-11-2014 08:07 PM
I recently went through a large RFP at work for interior lighting and learned that some high priced LED's can be junk, and some low price led's can be great and its difficult to tell.
Im looking water proof white bilge lights, colored strips for the gun wales, white courtesy lights for the interior and maybe under water lights. Any recommendations?
thanks
Fast N Loud 02-11-2014 08:34 PM
www.lizardleds.com
I recently bought two boat kits and have been pleased with the results.
I will post some pics of them soon.
US1 Fountain 02-11-2014 09:41 PM
Bought all my interior LED bulbs from Marinebeam. Somewhat pricey, but worth it IMO.
I look for the wide voltage, ex 10-30v, range specs, vs just the 12v rating.
http://store.marinebeam.com/technicalinfo.html
I did buy a roll of waterproof LED thru ebay for $15. So far it has been just fine.
inxsinxs 02-12-2014 03:22 PM
I also have had very good success with ebay lighting. You will find something that will fit your need and at good price.
If you want to kick it up a notch try Varad (info at http://www.varad.com/v4/) undercar lights that are multifunctional and you can actual make your lights go with the music. I have 2 sets on my boat. One set I have mounted under the transom for 3 years and they work great.
VoodooRob 02-12-2014 04:12 PM
1 Attachment(s)
I too bought the $20 LED roll off eBay and use it in my engine compartment. Mounted it with 3M emblem tape, the tape supplied was junk off the get go. The lighting is holding up, no issues. [ATTACH=CONFIG]518498[/ATTACH]
low_psi 02-12-2014 04:28 PM
superbrightleds.com the only place I by LED lights from. They have some really nice waterproof stuff. Very cost effective as well.
242LS 02-12-2014 06:45 PM
What do people use to stick to fiberglass? I used a thick Velcro strip on the fiberglass gun wales of my engine compartment. After about a month, it started falling off.
lightning jet 02-12-2014 07:19 PM
these are like the lizard
3 Attachment(s)
16 foot roll rgb with remote and control 30 bucks on ebay IP 65 rated and I stuffed them into a half inch insert rub rail
VoodooRob 02-12-2014 10:40 PM
Auto zone or Pep Boys, 3M emblem tape ( gray tape with red film on adhesive side )
US1 Fountain 02-12-2014 10:59 PM
Picked up the double sided tape at Menards paint dept. Not sure if it is 3m or not, but has the red peel off covering. It's more of a thick rubber tape than the thin scotch type tape that is usually supplied with the ebay lites. I have a strip under my swim platform and it gets soaked, 2 yrs and still stuck like the day it was installed.
ealesh33 02-13-2014 11:27 AM
I ordered from SuperBrightLeds, from looking around they looked quality, good price, they have side emitting lights so when you hang them from your gunnels they point down instead of straight into the other side of the gunnels, and they are IP67 rated which means they can be completely submerged in water up to 3 meters for up to 30 min. Here are the exact ones I got:
http://www.superbrightleds.com/morei...light-bar/123/
