procharger fuel system help fuel regulator
I recently changed out my fuel system got rid of the procharger regulator and added a Aeromotive 1 to 1 along with a high flow fuel pump and bigger fuel lines . I have a Mefi tunning program and was wondering should I be tunning using the 1:1 regulator which is increasing fuel pressure 1 psi to 1psi of boost. Or do I just leave the fuel pressure constant and tune for extra fuel through the MEFI ?? . It is a 454 Mag efi running 5-6 psi of boost. I also use a 2 bar Map sensor to capture the boost . As of today it is tunned for proper air fuel using the 1to regulator ?
THX |
Use the regulator to increase the fuel pressure to the injector to offset the boost pressure in the manifold that's pushing on the injector.
Originally Posted by GPM
(Post 4076917)
Originally Posted by nitrouspaul
(Post 4077644)
that's sounds great but how do you get to a safe afr like 11.8 or 12 to one when boosted at max rpm since the mefi is operating outside its ability to read
(Post 4077644)
| All times are GMT -5. The time now is 10:56 PM. |
