Someone said something about off shore, What u think,I run a boat onshore, last time I checked once I'm out on river I'm offshore
That just goes to show that u think u better. Lol. U still suck
:whistle:
Wow is all I have to say lol
DAZED AND CONFUSED,it,s ok bugerweiser we know you cant help it.:readinghelp:
Check out this bad boy. ''Project Punisher"
I like the doel fin on the out drive. Pretty sweet. Also, dont mind the blowby from the valve cover, its the total seal gapless rings doing their thing http://www.youtube.com/watch?v=84XEbisjhZM |
Ya prob, but I still needed to know right combo to get most out of motor,
Wow is right! This is too funny, how about a little respect buddy instead of spouting off, a few have given some advise but it appears you aren't really interested. This is a great site with lots of info, but as I was told a long time ago, "you will learn more if you shut your mouth and open your ears". Good luck with your project!
Whatever not site for me
Originally Posted by buddy1234
(Post 4084542)
(Post 4084545)
whatever not site for me
Damn and I was enjoying this thread
Bye Bye Buddy it`s a good site if you just listen to what others have to say,and don`t be so thin skinned.
Sorry, not buying it. I can see a bunch of swinging dicks sitting behind a computer, laughing their ass off right now. This site needs to charge $1 to get a screen name to clean things up for a while. Just saying
:Whatever:
Originally Posted by abmotorman
(Post 4084575)
Why bother coming here and asking for help if u are not truly interested in the responses? Many of us really benefit from the advice that we get from these experienced boaters. We dont need rookies starting pissing matches spoil itt
(Post 4084528)
(Post 4084441)
whatever im out of here, ill find somewhere better, I was going to upload viv of rpm on river, with 5 people on board, but who cares, F U did I spell that right
I thought all the fun and drama was over on the Tech discussion board! :popcorn: My guess is that the OP is in his early 20's with his first boat. There is some good info on these forums, but you have to have a sense of humor about it. Good luck with it! |
I hope to see this 7,500 RPM screaming Sea Ray on the river this summer! Must have strapped an old Sun tach to the steering column as I can't ever recall a Sea Ray with an 8K RPM tach! Is the boat named "Floating Lifters"?
Darr? Or copied his "buddy"?
Not Darr.
it has a 10k tach, if u around Peoria u would have seen me, had that boat out for past several years, and your right old tach went to 6k,
Must be running a nitrous cam to spin it that high. :helmet:
Didn't we deal with this azz wipe before under a screen name of "racer" something? The diarreah of the mouth smells familiar.
If you are going to stereotype us for having more money than brains, we are going to stereotype you right back. We know type. The only reason you have more brains than money, is because you only have 37 dollars. We learned a long time ago that the cob job approach may work in a little boat long enough for you to burn the gas money you earned collecting bottles and cans, but for us serious boaters that want reliability it so going to take the right stuff. I went from trying to keep you on the conservative side and safe you some grief, to now wanting to watch you fail in person. Please keep us posted Btw, the sea ray obviously has a malfunctioning tach, and no one saw u cause no one here cares about a pile of crap sea ray doing 28 mph. Head over to thehulltruth.com for help with the tach. |
I thought this all sounded familiar but I've been doing a lot of glass work in a small garage so between resin and the bullet heater brain cells are dropping like flies!
All of these sound familiar. Lol
hay bugerweiser,did you not say this site is not for you?please tell us what camshaft you have in your 7,500 rpm 350.il just go ahead and say what everybody is thinking,you are a big bull sheeter but you are amusing!
It probably wound the hell out of the old tach for the 6cylinder that was in the boat before... Might want to check the new tach and make sure it's set for 8cyl this time
(Post 4084464)
was wanting real info but get sarcasim, site is for birds, I will b on water, have 3 boats, for that, 18ft webbcraft 307, 21ft searay 350 and 454 21ft raven will b on water in summer, lol
... and a dictionary . wait you probably didn`t understand.. I`ll try again: Y knot cell tose end wit D $$ buye 1 d cent boat...end a dicksionary :daz: |
Buddy1234 -
Didn't you beat me racing once - Bench Racing . On a serious note, with your big block what you need to wake up that boat is a set of bleed up lifters, adjustable roller valves, peanut butter port heads (I run'm - see info under my name to left),Harley two pump carb, corvette heads, and an external cam pulley. To start with. As you mentioned, going to a bigger outdrive always provides more speed - my experience is 10mph or faster. |
Originally Posted by SB
(Post 4085503)
Buddy1234 -
Originally Posted by Knot 4 Me
(Post 4085505)
It's all Bravo II's these days and lap-Finnish elephant ear aluminum props. :coolcowboy:
(Post 4085503)
Buddy1234 -
Didn't you beat me racing once - Bench Racing . On a serious note, with your big block what you need to wake up that boat is a set of bleed up lifters, adjustable roller valves, peanut butter port heads (I run'm - see info under my name to left),Harley two pump carb, corvette heads, and an external cam pulley. To start with. As you mentioned, going to a bigger outdrive always provides more speed - my experience is 10mph or faster. The external cam pulleys really wake it up. I have the small pulleys on mine. The cam spools up faster that way. |
well i put on a bigger outdrive and i only picked up 7 mph.iffen i can finder il put r up da viv.
7500 rpm. you didn't change tach. it is reading 33% high. also you are running 1.65 or 1.68 gears in the v6 drive so engine IS over revving, but not that much. oh, if you have 188 heads, the 454 is a 365 hp mag motor, not 330 hp standard motor. much better engine to start with. what I was saying about the raven hull, is, spend what you like in time-energy on motor-drive, the boat will go fast and look good. I woulda bought it for 500 in a heartbeat if it fell in my lap. but be on lookout for a better hull to repower with that package in the future. you obviously know how to buy right. a 22 velocity, a Baja hammer, any 24-7 hull. and not even talking resale value, boats aren't worth the cost of building anymore. just a hull that will hold up to the pounding a boat gets when driven hard. good luck.
This thread reminds me of a "cummings" forum thread. How do I install a smoke switch to oral coalle? :whistle:
Found his brother in this old thread
http://www.offshoreonly.com/forums/g...ce-please.html sotofast5U |
Originally Posted by 4bus
(Post 4086427)
Damn skippy! Peanut butter port heads will rev you right on up o 7,500 in a Jif !!!!
You stupid fackz that try and build big motorz to have fun just need one of these
http://www.seaboundsupply.com/davis-...FYN0Ogod4g0ABg Hole shots like a mustang b!tch!!! |
| All times are GMT -5. The time now is 09:58 AM. |
