whats the difference between these two couplers
2 Attachment(s)
one is from the 454 i took out the other is from the 502 im putting in
not sure what changes I need to make to install the 502 now thanks again in advance[ATTACH=CONFIG]519977[/ATTACH][ATTACH=CONFIG]519978[/ATTACH] |
Looks like the 454 is the long snout and the 502 has the std coupler. Same spline nothing to change.
The coupler on the right is an aluminum coupler .The coupler on the left is Mercury's heavy duty coupler made for heavier boats that idle a lot or troll alot.the quality of the hd coupler far exceeds the aluminum coupler.
There are 2 versions of the short coupler, aluminum and steel. I might be wrong, but I don't think the aluminum one is available any longer. The short one is necessary for driveshaft applications.
Originally Posted by stimleck
(Post 4086813)
not sure what changes I need to make to install the 502 now thanks again in advance[ATTACH=CONFIG]519977[/ATTACH][ATTACH=CONFIG]519978[/ATTACH] this is the heavy duty bravo coupler http://www.bing.com/images/search?q=...lectedIndex=10 the one on the right is just the standard duty big block coupler.. |
One is a penis the other a vagina. Your mom not teach you about the birds and the bees??
Originally Posted by ICDEDPPL
(Post 4087080)
besides, they are both vaginas. one is just fatter than the other...
So I guess ill need ti swap them to install the 502 in my boat with a bravo?
Originally Posted by FIXX
(Post 4087073)
the one on the left is a gen II alpha coupler ,,,,
Fixx if I`m referring to you I`ll quote you otherwise I`m replying to the OP. Internet 101 so calm down there buddy
Sounds like the heavy duty one is what you should run with a high performance (i.e. 500+ HP) engine. Too bad it is about twice as much as a standard Bravo coupler. I personally don't know anyone running the heavy duty one - two friends of mine were both running supercharged engines on the standard coupler and have not heard of any failures. I guess if you are running a big heavy boat with a lot of power it might be worth the upgrade. Main thing is keep those splines greased!
(Post 4087282)
It will be fine I've run 550+ hp in a 40' 10k boat
Regardless of what coupler you select -- Make sure you check engine alignment - I would guess it doesn't matter which one you select - if your engine is out of alignment it will chew it up in no time-- I've got the bills to prove it!
3pointstar |
I have almost no experience but are you sure thats an alpha coupler? I ask because the guy I bought the motor from had a bravo xr drive?
(Post 4087073)
Yes its barely 400 hp in a 5k boat (26 ft)h
can anyone confirm or clarify that the vagina is in fact an alpha coupler as FIXX suggested? I'm pretty sure the previous owner ran a bravo
Originally Posted by Budman II
(Post 4087399)
(Post 4087515)
did he say something about sticking a finger in a hole?
better a finger than something else lol
The post actually confused me because the photo of teh vagine coupler in my original post is the actual coupler. This post says "if it looks like this its an alpha" but the photo in that link is an "outy" similar to the coupler on the 454 which is a bravo coupler for sure. I just need to confirm if the "inny/vagina" coupler will fit my bravo I guess I just need to try it when the drive comes back from teh paint shop? Ill have to really stick it in!
Originally Posted by mike tkach
(Post 4087667)
I believe couplers are interchangeable. just how long lighter one lasts with a heavy foot.
alpha and bravo couplers are interchangeable?
Originally Posted by dereknkathy
(Post 4088175)
The inny is the same coupler that came on my 454 mags. If you take the bellhousing off you will see the inner plate is round and has about 8 bolts connecting it to the flywheel. The couplers with a three bolt pattern attaching them to the flywheel are what you do not want. I would take a picture with the housing off and ask again.
The one on the right is a HP coupler for a Bravo drive. It is round and six bolts hold it on the flywheel. I got mine from CP.
thanks
Ill do that tonight
Originally Posted by Port Monster
(Post 4088198)
(Post 4087667)
(Post 4087887)
The post actually confused me because the photo of teh vagine coupler in my original post is the actual coupler. This post says "if it looks like this its an alpha" but the photo in that link is an "outy" similar to the coupler on the 454 which is a bravo coupler for sure. I just need to confirm if the "inny/vagina" coupler will fit my bravo I guess I just need to try it when the drive comes back from teh paint shop? Ill have to really stick it in! |
Stimleck I have run both couplers ( one on left with the triangle mounting plate is typically on small displacement motors ) and the HD one on the right ( round mounting plate with blunt end found on large displacement apps ) behind my BBC with no issues. I changed mine when I swapped from an Alpha to a Bravo 1 for piece of mind but don't think I would have had any problem using either.
So in case anyone is around for advice the 454 coupler only had 3 bolts and came from the factory with a bravo the coupler opening wont fit the alignment tool its too tight what should I use?
(Post 4130852)
seems like you have the wrong alignment tool |
Stimleck = where are you located??
hi folks well it turns out that the tool fits fine I just needed to push a bit doh! the stock 454 coupler only had 3 bolts the coupler on the 502 had 8 I think
I stuck with that one, I did notice that the 454 had a plate behind the flywheel, is that mandatory? located in toronto
(Post 4130987)
plate behind flywheel is probly balance plate to adapt 350 or other neutral balance flywheel to ext balance 454. not NEAR as good as correct flywheel. also, they could be wrong about needing it or getting correct one. ck flywheel part number and look for balance weight cast into outside of flywheel.
Full circle coupler on the 502 and other bravos ,is held on with 6 bolts...
(Post 4131056)
I stuck with that one, I did notice that the 454 had a plate behind the flywheel, is that mandatory? located in toronto |
| All times are GMT -5. The time now is 05:43 PM. |
