-   -   Come along for the adventurous ride of adding a transom shower and what ever else (https://www.offshoreonly.com/forums/do-yourself-boating-budget/310878-come-along-adventurous-ride-adding-transom-shower-what-ever-else.html)
92nsx 04-12-2014 03:58 PM
Well I figured I would show my progress of add a transom shower to my 265 DVX, and maybe a couple other goodies.
To recap last springIi added LEDs to the cockpit and cuddy
http://i212.photobucket.com/albums/c...psv8ccgkhi.jpg
http://i212.photobucket.com/albums/c...psa2837ngu.jpg
Along with new bluetooth tunes
http://i212.photobucket.com/albums/c...ps4c203bcc.jpg
And a new top end
http://i212.photobucket.com/albums/c...ps41dda2b2.jpg
Time to get the boat back up next to the house and start the next project.
http://i212.photobucket.com/albums/c...ps67vz6gs9.jpg
Now this spring Ill be adding a transom shower.
First order was last fall taking some photos so I had the winter to find what size tank, pump, shower, ect. would fit, I knew the third battery would have to move or get elminated all together.
http://i212.photobucket.com/albums/c...pstzi2gjee.jpg
http://i212.photobucket.com/albums/c...psy7veajfq.jpg
I found a 10 gal tank, (9"X14"x19") that should work perfect. First order was to cut a hole on top and install a inspection plate for filling. Then made a alum. frame to hold it in place. Yes, I know it has a 1" fill plug but Im not going to cut another hole in the side of the boat at this time just to fill the tank form the out side.
http://i212.photobucket.com/albums/c...psop9igrmr.jpg
http://i212.photobucket.com/albums/c...psxbay9lfy.jpg
Next I moved the trim pump (square to the world vs the30 degree angle it was at) removed the battery the downs, and misc wires that were mounted in the area where the pump and water tank would go. Then started to lay out where it would all fit. I think I will mount the pump will rotate 90 degrees from this photo.
http://i212.photobucket.com/albums/c...psmxvlk0c7.jpg
Here is the shower i picked up. Buddy has one with the rumbber flapper for a cap and it had broke off a coupel times now so I went with the SS cap. (might bite me in the ass later you will see)
http://www.scandvik.com/images/Produ...134_Detail.jpg
Now to find a spot to mount the shower. Im thinking right here under the grab rail on the starboard side
http://i212.photobucket.com/albums/c...pshwx677ul.jpg
CRAP!!! Not much room actually to mount the cup and have the hose pull in and out smoothly. There is maybe 4" from the mounting hole form the grab rail to the to pof the transom (gray part). Remember I have the solid SS cap for the shower. It dosent look like there will be enought room to open the cap all the way. Umm, i might have to rub or rest on the grab rail once open. The opening or hole size for the shower is 2 3/4".
http://i212.photobucket.com/albums/c...psgeeupbwy.jpg
A wider shot of the area.
http://i212.photobucket.com/albums/c...psnqn3g7vy.jpg
This as far as I got at the moment. It was beer thirty.
92nsx 04-12-2014 04:16 PM
Well today I was able to mount the tank, pump and get the wires ran.
http://i212.photobucket.com/albums/c...psy0gtxucj.jpg
The fitting for the hydraulic hatch ram was in the way, so ran up town quick and picked up a 90 degree fitting quick. This way the tank clears with kinking the tube.
http://i212.photobucket.com/albums/c...ps2cnur6fm.jpg
http://i212.photobucket.com/albums/c...ps13smdbig.jpg
http://i212.photobucket.com/albums/c...psvvqf8st6.jpg
Well now all I have left to do is drill the 2 3/4" hole!!!! I picked up the hole saw today, Once home I found out I don't have the correct arbor that fits in the center :( So the hole will have to wait for another day. Now to figure witch way to mount the shower cup. Maybe it might work mounting the lid so it opens to the side so it clears the grab rail??
http://i212.photobucket.com/albums/c...psrkxs2emz.jpg
Or
http://i212.photobucket.com/albums/c...psmkpwyn1z.jpg
http://i212.photobucket.com/albums/c...psxizeijbr.jpg
US1 Fountain 04-12-2014 05:18 PM
If mounted vertical as in 1st pic, either have to lower it more or you will be limited to the lid not opening past 90* before it hits the grab handle, thought that is the normal mounting direction. Does the lid snap close? If horizontal like 2 and 3rd pic, will the lid flap open?
92nsx 04-12-2014 05:38 PM
No real room to move it down due to transom in the way, witch the top cap over laps. Yes the lid dose snap closed and yep it will open flat if I mount it horizontal. More and more I think it will have to mount horizontal. The emblem will look more like a bright light vs a shower:lolhit:
92nsx 04-18-2014 09:32 AM
Well Easter day is looking like decent weather to get back working on the boat.
Question: When drilling the 2 3/4" hole threw the swim deck, how can I keep the wood/fiberglass from blowing out on the back side? There is no room to mount a backer plate. Just slow and steady?
I know to keep the gel coat from chipping/cracking Ill run the saw in reverse untill it threw the gel.
Once the wood is exposed what should i put on it from rotting away? Just cover in the 3m 4200? I want the cup to be removable some day just in case it would get broken or something happens to it and needs to be replaced.
US1 Fountain 04-18-2014 08:40 PM
Push very lightly when you feel it's about to pop thru to minimize splintering the wood/glass backside. Let the hole saw teeth do the cutting, not pressure. And low RPM. Slow enough you can see each rev. Go to Autozone or Menards and pick up a cheap can of fiberglass resin/hardner and seal the exposed cut out.
92nsx 04-21-2014 10:52 AM
Well drilled the hole, wish i would have went 1/8" lower since the lid scrapes the grab bar a little.) There isn't much to the swim deck. Looks to be all fiberglass no wood.
http://i212.photobucket.com/albums/c...psyr39uzuc.jpg
I mounted it horizontal because when i had it normal (lid opening up) the hose rubbed big time on the latch and cover.
http://i212.photobucket.com/albums/c...psf7yxjy18.jpg
http://i212.photobucket.com/albums/c...pstmfhutkq.jpg
http://i212.photobucket.com/albums/c...psair31syq.jpg
I forgot to get a photo of the inside but will get that later today.
US1 Fountain 04-22-2014 07:21 AM
Looks good. Can you slot the rail mounting holes upwards enough to clear?
92nsx 04-22-2014 08:01 AM
Thank you. Good thinking, I might be able to just loosen the bolts holding the grab rail on and wiggle it up just a smig. We all know baja construction and i'm guessing there is a little wiggle room in the mounting holes.
Wes Burmark 04-22-2014 10:14 PM
Nice work. Enjoyed reading your post.
92nsx 04-23-2014 10:00 AM
Thank you.
Once the weather gets nice again up here in MN, More projects to fallow. Mount mini water pump and 3 L. "camel" bag under sink in cuddy for the sink to have water again.
New decals on the bravo 1, replace tires on the trailer along with a new winch.
92nsx 05-05-2014 03:07 PM
Finally a nice day out to finish up the shower, and get rolling on other projects.
Finally ran the power wire up to the Acc switch up at the helm.
Wow this pump has some power! Im holding it at 5-10 degrees up and she shoots 10+ feet. I might turn it down since it emptys my 10 gallon tank in about 2 mins.
http://i212.photobucket.com/albums/c...ps5oovymet.jpg
This is the camal pack nad pump Im going to use for the sink in the cuddy. The bladder is only holds 3L of water but i wanted it to be a soft side bladder so it can easly be moved or pulled out from under the sink. Also got the quick connect with check valve on both sides so filling it will be super ez. Just pull the bladder out and fill-r-up.
http://i212.photobucket.com/albums/c...psrshv3cbb.jpg
This is the smallest pump i could find. Should work perfect. It is super quiet. But just like the transom shower pump, this little thing can move the water!! 4L per min.
http://i212.photobucket.com/albums/c...psqbcxtbdp.jpg
Once I started to hook the pump up to the switch in the faucet, the stupid little tabs broke off the switch :( But i was able to find one at McMasterCarr. So that should be here in a couple days. Hopefully the weather stays nice.
http://images2.mcmaster.com/Contents...g?ver=30705281
92nsx 05-08-2014 09:40 AM
Switch is replaced, faucet is in along with bladder and pump. it drains the 3L bag in no time.
Don't mind the dirtyness, still needs the spring cleaning in the cuddy
http://i212.photobucket.com/albums/c...psmyogjaiz.jpg
http://i212.photobucket.com/albums/c...pskvfar3lh.jpg
http://i212.photobucket.com/albums/c...pss1rknttt.jpg
http://i212.photobucket.com/albums/c...pscsuqksr5.jpg
The Decals on the bravo were looking like crap and made the drive look junky...
http://i212.photobucket.com/albums/c...psjxzvhmcd.jpg
http://i212.photobucket.com/albums/c...psm1nbjgxr.jpg
New decals. Also I thought the power trim decal looked better with letting towards the base vs the old way.
http://i212.photobucket.com/albums/c...psxnkzhl7h.jpg
http://i212.photobucket.com/albums/c...ps9ag5gs1u.jpg
http://i212.photobucket.com/albums/c...psy0dbkod4.jpg
This side decals are good, but not aligned :( I didnt replace them yet..... The SN # is stamped into the decal, once I remove it i wont have it any more. Not sure what Im going to do yet.
http://i212.photobucket.com/albums/c...psfqnruqg0.jpg
Thats all I got done before the rain moved in
