350 rebuild milky oil.
Get guys I had the weirdest thing happen to me and I wanted to see if anyone has had this issue. I was breaking in my new motor(94 350) and after running it for about an hour I saw milky substance in the valve covers. I pull the drain plug and oil is like a cream color but didn't look like water in the oil. I pickle the motor in diesel change the oil and filter and ran the motor for 4 hours and it didnt happen again. Do you guys think it could have been the grease they used to build the motor?
I just did a cam swap on a SBC. I used a FT cam and Comp break in oil. When I drained the oil it wasn't what I'd call milky, but it did have a shiny tint to it.
Ok. Thanks man. I used a comp cam as well.
Yeah, it's scary seeing all that shiny crud in there. It's a combination of the cam break in lube and fine metal shavings from new metals wearing together.
Yeah I wa having a mini heart attack.
You likely don't still have the old oil do you? If so, let it sit in a container for a few days and the water should settle out if that is the issue. If not, then you have better news.
| All times are GMT -5. The time now is 12:19 AM. |
