-   -   plugging drilled primary butterflies? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/312134-plugging-drilled-primary-butterflies.html)
SB 05-15-2014 08:33 AM
Originally Posted by motor (Post 4122180)
cha-ching
Better than outdrives !
High shift rpm is #1 killer to outdrives. In my experience.
MILD THUNDER 05-15-2014 08:34 AM
And in this case, the transmissions. They do not like being shifted over 1100-1200.
motor 05-15-2014 02:14 PM
When I read riveted I was assuming the OP meant the screws were staked on the backside
Originally Posted by MILD THUNDER (Post 4122410)
I would like to think his holley 4150 carbs have screwed on throttle blades. I suppose you could booger them up with epoxy to save a few bucks.
The majority of marine supercharged engines have no real need for drilled throttle plates.
