-   -   underwater led (https://www.offshoreonly.com/forums/do-yourself-boating-budget/313622-underwater-led.html)
kevinb230 06-11-2014 12:58 AM
underwater led
I'm going to be installing lifeform led's tomorrow. Anyone have any tips or words of wisdom? What is a good sealant to use for gel coat?
Thanks!
neva satisfied 06-11-2014 05:15 AM
3m 4200
happy hours 06-15-2014 09:10 AM
Measure twice, Seal everything with 4200 or 5200 , chamfer the hardware holes after drilling to eliminate spider cracking with self tappers go in.
Drock78 06-15-2014 12:50 PM
Make sure you post pictures of them on on the water.
low_psi 06-16-2014 03:56 PM
You can use a drill bit a few sizes larger than the hole you have made and run the drill in reverse to make the Chamfer. Definitely chamfer. Or you WILL have spider cracks. Maybe not right away, but the screws will create small one upon entry and before long, they will get big and ugly...
johnny b good 06-17-2014 11:34 AM
I would do all the above, plus putting some tape over the surface before you drill seems to help stop chipping.
